    Dismiss Notice
Repairing FHP TENV Leeson Motor
Discussion in 'Members Lounge' started by jpanhalt, Mar 27, 2017.
  1. jpanhalt
    jpanhalt Well-Known Member Most Helpful Member
    Jun 21, 2006
    6,059
    519
    Cleveland, OH, USA
    ONLINE
    I have a TENV fractional HP (1/6 HP, 3.2 FLA at 115VAC) Leeson motor on a septic aerator. The bearings froze and are shot after just 2 years. The armature has a plastic internal fan that makes removal of the armature and replacement of the end bearing difficult. There is no external capacitor. The fan can probably be removed with a little heat, but I am worried about getting it reattached well. I would use Loctite if I get to that point.
    Question: Is the fan really necessary?
    John
  2. Les Jones
    Les Jones Well-Known Member
    May 15, 2015
    1,474
    191
    Lancashire UK
    I think the fan is necessary. (The manufacturer would have saved the cost of the fan if it was not required.) You may be able to remove the bearing using a seperator tool like this one.
    I had to make one a few days ago to remove a bearing on a Dewalt chop saw. This is a link that shows this type of tool being used on this type of chop saw.
    Les.
    • Thanks Thanks x 1
  3. jpanhalt
    Jun 21, 2006
    6,059
    519
    Cleveland, OH, USA
    ONLINE
    Problem was solved with a little more persistence and effort. Got the fan off without heat or damaging it. Will re-install with a little Loctite. My concern was that if the fan were damaged, it is not something I could buy retail.
    I am in urgent need to get the aerator fixed as my daughter and her family are visiting in a little more than a week.
    John
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. MaxHeadRoom78
    MaxHeadRoom78 Active Member
    Jun 9, 2015
    893
    72
    Canada Geog Cen of N.A.
    Is it sintered bronze or roller bearing?
    If sintered bronze and not overly worn it can be cleaned off and soaking in light oil for a while.
    Max.
  6. jpanhalt
    Jun 21, 2006
    6,059
    519
    Cleveland, OH, USA
    ONLINE
    It is/was ball bearing. Even the shields are distorted. Here is what they look like upside down:
    The long shaft is hollow and submerged. Air is aspirated into the sewage. The motor rests in a riser off a holding tank.
    For mine, the motor is enclosed on a larger bell housing. It is no longer made, and technically (EPA sort of thing) , I can repair with the same thing, but substitution of a functionally identical unit, e.g., one without the bell housing, would require recertification if my system, since the system and aerator were sold as a unit. Fortunately, that law is rarely enforced on home owners; however, it is a risk should there be a problem.
    John
  7. KeepItSimpleStupid
    KeepItSimpleStupid Well-Known Member Most Helpful Member
    Oct 30, 2010
    9,964
    1,099
    Could you change to a ceramic bearing?
  8. jpanhalt
    Jun 21, 2006
    6,059
    519
    Cleveland, OH, USA
    ONLINE
    It is a common 6203 (metric) bearing. Picking up two SS, rubber-sealed ones tomorrow. Cleveland has a very large bearing warehouse on the West (my side) of town.
    John
  9. KeepItSimpleStupid
    Oct 30, 2010
    9,964
    1,099
Share This Page
