reducing voltage not amps?
harps
(i meant to post this in general chat sorry)
hello, a new and inexperienced electrician here : )
i have a 17 volt ac>dc power supply and it can offer 1.1 amp
i hope to power a little relay which needs only approx 5v and 40 milli amps to trigger it. So when I use a variable resistor on the psu to drop the volts down to 5v, the amps drop too and so much so I cant power my relay with it. : /
i know the relay works at 5 v as i have another psu to test it with
maybe i need change the regulator inside this 17v psu?
thanks for any help. : )
There's no need for a regulator, a simple series resistor will do.
Use Ohm's law
R = (17-5)/0.04 = 300R
So use a 270R resistor (the nearest E12 value) in series with the relay.
thanks, i did try a resistor as you mentioned, it did reduce the volts but the current came down far too much for my relay,i connected it in series as you say : / might be something else i did wrong. anyway i bought a 5v regulator and it did the trick. it reduced the volts but the amps where still reading high on my test meter.
i made this type of circuit below and used a diffrent psu running at 10v (bringing it down to 5v using this circuit) the parts were so cheap i built the whole thing, as the relay was for routing audio the dc smoothing might have helped any noise crosstalk , well, its all for fun : P
peace : )
Then you've got the current consumption of the relay coil.
Measure the relay coil's resistance with a DVM and tell me what it is.
