    Dismiss Notice
Reading RFID tag through software UART on 8051 failed
Discussion in '8051/8951' started by mik3ca, Aug 20, 2017.
  1. mik3ca
    mik3ca Member
    Jun 24, 2017
    184
    1
    Here's my situation.
    I attempted to create my own RFID reader with the help of an RDM6300 reader module (with UART) with results sent to a computer via a serial cable.
    I have already dedicated the 8051 hardware UART to the PC so my only option is to create a software UART to interface with the UART on the RDM6300 module.
    I have borrowed ideas from here: http://webcache.googleusercontent.com/search?q=cache:CyacPmYhWY4J:https://www.8051projects.net/wiki/8051_Software_UART_Tutorial+8051+software+uart+asynchronous&num=50&client=opera&hs=ZUz&rls=en&channel=suggest&hl=en&ct=clnk
    This is my code:
    Code (text):
    RX equ P3.3 ;pin on micro which RDM6300 TX pin connects to
    ;reset variables
    clr TR1
    mov P1,#0FFh
    mov P3,#0FFh
    ;enable 9600bps to PC
    mov PCON,#80h
    mov TH1,#0F4h ;9.6kbps
    mov SCON,#50h ;serial mode 1
    mov TMOD,#22h ;auto reload for timers
    setb TR1
    ;print init message
    mov DPTR,#Minit
    lcall lprint
    main:
    ;call serial receive function
    lcall surec
    ;load hex number table and convert received character (in accumulator) to hex
    mov DPTR,#hex
    mov B,#0Fh
    div AB
    ;do 1st hex character
    movc A,@A+DPTR
    clr TI
    mov SBUF,A
    jnb TI,$
    ;then next character
    mov A,B
    movc A,@A+DPTR
    clr TI
    mov SBUF,A
    jnb TI,$
    ;print space
    clr TI
    mov SBUF,#20h
    jnb TI,$
    ;print anoter space (to make screen look nice)
    clr TI
    mov SBUF,#20h
    jnb TI,$
    sjmp main
    ;print string from memory until character code 0 reached
    lprint:
    clr A
    movc A,@A+DPTR
    inc DPTR
    jz exitp
    clr TI
    mov SBUF,A
    jnb TI,$
    sjmp lprint
    exitp:
    ret
    ;calculate bit time based on (((crystal/baud)/12) - 5) / 2
    ;crystal = 22.1184Mhz, baud=9600
    BITTIM equ 0BBh
    ;and pre-calculate 1/2 bit time
    BITTIMH equ 5Dh
    ;Software Uart RECeive routine
    surec:
    ;wait for start bit (bit=0)
    jb RX,$
    mov R0,#BITTIMH
    djnz R0,$
    ;wait 1/2 time and if bit is 0, start over
    jb RX,surec
    ;load 8 bits into accumulator waiting 1 bit time for each
    mov R1,#8h
    clr A
    surecl:
    mov R0,#BITTIM
    djnz R0,$
    mov C,RX
    RRC A
    djnz R1,surecl
    clr C
    ret
    hex:
    db '0123456789ABCDEF????',00h
    Minit:
    db 0Dh,0Ah,0Dh,0Ah,'RFID Card Reader V1.0',0Dh,0Ah,00h
    When I execute it, hex values do appear when the card is on the module but they don't match up with the numbers on the card. Also, I read somewhere that the card byte format must start with a "2" then several bytes then a value "3".
    Is the equation (((crystal/baud)/12) - 5) / 2 incorrect for determining bit time? or is there something else I'm doing wrong?
  2. Ian Rogers
    Ian Rogers Super Moderator Most Helpful Member
    Mar 28, 2011
    9,251
    911
    Rochdale UK
    Trying to get my head around this... I'm wondering if its a typo!! If the pin is still high carry on else start over..
    So shouldn't it be jnb RX,surec?
    Whoops... No... I keep forgetting that 8052 pins are reversed...
  3. ci139
    ci139 Active Member
    Apr 12, 2012
    469
    37
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. mik3ca
    mik3ca Member
    Jun 24, 2017
    184
    1
    oops. typo in the comment. It checks for 0 (logic low) then wait 1/2 bit time then check for logic low again
  6. mik3ca
    mik3ca Member
    Jun 24, 2017
    184
    1
    Ok Now I'm not sure if the data format is right at all. I'm using an RDM6300 card reader module and reading the data through the software uart and I tried EMI4100 compatible cards with the following labels:
    004190809 063,62041
    004190808 063,62040
    When I scanned the first 13 bytes of the card, I received the following output as hexadecimal:
    1st card: 023B3B33004E4A4A35383B3448
    2nd card: 023B3B33004E4A4A35383C3447
    However the documentation for RDM6300 states that the termination byte should be 03 and I don't see that anywhere. I guess I will try more bytes just to see.
    But I'm curious as to why I get 48 and 47 as output when that doesn't represent ascii 0 and ascii 1.
  7. Ian Rogers
    Mar 28, 2011
    9,251
    911
    Rochdale UK
    Okay!!
    Two things wrong....
    1) timings.... You forgot the /2 at the end so your bit delay should be 0x5d and the half should be 0x2e.
    2) BCD.... You are dividing by 15 and not by 16 you need to change mov b,#0fh to mov b, #10h.
    Works now
    Code (asm):
    ;reset variables
    clr TR1
    mov P1,#0FFh
    mov P3,#0FFh
    mov PCON,#80h
    setb TR1
    ;print init message
    mov DPTR,#Minit
    lcall lprint
    main:
    lcall surec
    mov DPTR,#hex
    mov B,#10h
    div AB
    movc A,@A+DPTR
    clr TI
    mov SBUF,A
    jnb TI,$
    mov A,B
    movc A,@A+DPTR
    clr TI
    mov SBUF,A
    jnb TI,$
    ;print space
    clr TI
    mov SBUF,#20h
    jnb TI,$
    clr TI
    mov SBUF,#20h
    jnb TI,$
    sjmp main
    lprint:
    clr A
    movc A,@A+DPTR
    inc DPTR
    jz exitp
    clr TI
    mov SBUF,A
    jnb TI,$
    sjmp lprint
    exitp:
    ret
    BITTIM equ 05dh
    BITTIMH equ 2eh
    surec:
    jb RX,$
    mov R0,#BITTIMH
    djnz R0,$
    jb RX,surec
    mov R1,#8h
    clr A
    surecl:
    mov R0,#BITTIM
    djnz R0,$
    mov C,RX
    RRC A
    djnz R1,surecl
    clr C
    ret
    hex:
    Minit:
    end
  8. mik3ca
    mik3ca Member
    Jun 24, 2017
    184
    1
    That point #2 kept me puzzled for a while there but yes I'll followed point 2. I followed point 1 through experimentation before you posted this.
Share This Page
