Question about dual CCS
charlie_r
I'm building some LED based lights for my work trike, intended as safety daytime running lights, but with the ability to be used as headlights at night.
Using a pair of LM317s in constant current configuration, with the input source switched between them.
Would a diode be needed on the output to prevent reverse current damage to the inactive current source, like this? Yes, I know a diode will add an additional voltage drop of ~1.7V to the circuit, but given the power is being supplied by an 8Ah SLA, I think I have the headroom available, since I am driving a trio of 1W Osram type white LEDs wired in series with a typical voltage drop of 3.2-3.6V
Low beam would be configured for 90mA and high beam for 250mA.
Circuit:
Thumbnail is clickable.
No prob. And a reasonable idea.
What ever they drop, it won't matter in this configuration.
3v0, I guess that's why they pay you the big bucks.
Yes, much simpler, and easier to do.
I could use that for my tail/brake lights as well.
Thanks!
I set up a test bed for 3v0's circuit, and found that 60mA -->320mA gives me the effect I want.
Resistor values are 17ohm for 60mA, and 5ohm for 320mA.
This keeps me comfortably below the max constant current for my 1W LEDs on a freshly charged battery. This is with the ammeter in the circuit, so I would expect a very slight difference without it.
I don't think there is enough head room for 3 3.6 volt LEDs and a regulator.
Hmmm.
Voltage checks:
Battery - 12.74V
On low power:
V-in to adjust - 4.27V
V-out to adjust - 1.21V
On high power:
V-in to adjust - 2.94V
V-out to adjust - 1.14V
I'd say it has just a small deficit, but nothing I can't live with.
