Put t on the left side? Vc = V * (1- e^(-t / R*C))
blueroomelectronics
It's high school math and I've simply forgotten how. Yes getting old is fun.
I want t (time) on the left side of the equation and Vc on the right.
Vc/V = 1- e^(-t /( R*C))
e^(-t /( R*C))=1-(Vc/V)
t/(R*C)=-ln(1-(Vc/V))
t=-R*C*(
ln(1-(Vc/V)))
I get something different:
And please. write your formulas mathematically correct!!! there are braces missing all over the place!
Good catch. The "C"s in the right side of the last two equations should be lower case (ideally, all the lower case "c"s should be subscripted). Those were typos. I have edited my original post to reflect this. My results and yours now match.
Some braces are missing in my equations because I copied and pasted William's equation.:eek:
I have edited my original post to reflect these corrections.
Ron,
It would be easier for novices if you eliminated the negative sign.
ie. t = R*C *ln{Vc/(Vc-V)}
ljcox said:
Ron,
For us math challenged members what is and where did the "ln" term come from?
Lefty
Lefty
Look here for explanation:
Its a standard exponential to natural log transform
A couple of simple examples to demonstrate.
Exp(1) = 2.718282
ln(2.718282) = 1.0
Exp(2) = 7.389056
ln(7.389056) = 2.0
Logs are used to get the exponent, here's how it's done:
[latex]z = x^y[/latex]
[latex]y = log_x(z)[/latex]
To get log to the base x:
[latex]log_xz = \frac{log(z)}{log(x)}[/latex]
It doesn't matter whether you use log to the base e or to the base 10 for this.
As far as e is concerned it should be obvious:
[latex]x = exp{y}[/latex]
[latex]y = log_e(x) = ln(x)[/latex]
ljcox said:
Ron,
Len, this won't work. The log of a negative number doesn't exist.
eng1. you are wrong sadly (according to my calculations)
eng1 said:
Well, 1-(V/Vc) and Vc/(Vc-V) are reciprocal and have the same sign, don't they?
You just made me realize that there is another typo in my original post (sheesh!).
t/(R*C)=-ln(1-(V/Vc))
t=-R*C*(
ln(1-(V/Vc)))
Should read:
t=-R*C*(
ln(1-(Vc/V)))
I have edited the original post to correct these errors.:eek:
You've tested for equality, but my point was if 1-(V/Vc) is positive (negative) at any instant, also Vc/(Vc-V) is positive (negative) at the same instant because it's the reciprocal.
Len's equation seems correct to me. I got it from Roff's equation applying the formula ln(1/x) = -1*ln(x)
As I pointed out above (we were posting at the same time), my original equation was wrong. Sorry, Len.
Roff said:
t=-R*C*(ln(1-(Vc/V)))
Yes, now the argument of the log function is positive ;)
After your correction, an equivalent equation is:
t=RC ln[V/(V-Vc)]
ljcox said:
I'm glad we sorted that out in the end!
With apologies to Sir Walter Scott...
Oh, what a tangled web we weave,
When first we practice to... help someone.
Well I put the formula into Just BASIC
VDD = 5
R = 649
C = .00018
Vc = 3.125
print R*C*(exp(1)*(1-(Vc/VDD)))
Turns out I've got to use the TLC555 version as it will be eaiser to implement.
Shall we start discussing ideal values for R1 & R2 :)
