Really........?jrz126 said:make a propeller clock, these are pretty cool, there was someone in the projects section that was building one. There is plenty of info on the net about them too.
Also, why do people put pls, pls, pls,, !!!!!!!!'s, and lots of .......'s in their posts? It is quite annoying
Personally, I find political tag-lines pretty annoying. Is it too much to hope that you'll remove it, now that your man has won?Also, why do people put pls, pls, pls,, !!!!!!!!'s, and lots of .......'s in their posts? It is quite annoying
JohnBrown said:Personally, I find political tag-lines pretty annoying. Is it too much to hope that you'll remove it, now that your man has won?Also, why do people put pls, pls, pls,, !!!!!!!!'s, and lots of .......'s in their posts? It is quite annoying
frances said:Make an ankle-worn pedometer that uses a two-axis accelerometer, and is thus able to calculate work done in climbing hills, as well as distance covered.
how does it work?
