Programming of MUC
rabhishek91
Hi everyone. :)
I am working on a code where i need to display messages on LCD depending on the input to MUC(Atmega32A).
Below is the program where i need to display messages based on PortA input.
First. i'll read the pin0 of PORTA (continously). Depending on the value of that pin i'll control LCD messages. I know i have made lot of mistakes in programming. This is my first program so i am unaware of what to use.
Is this programming method correct ? or do i need to use some other method ?
Please help me.
C:
int main()
   DDRA = 0x00; //configure portA as input
   while(1) // To run the program continuously
      if(PORTA&=1<<PINA0)//Check high on pin0 of portA
         DDRB=0xff; // Configure PORTB as output for data bus
         DDRD=0x07; //Configure PORTD as output for control lines
         init_LCD(); // initialization of LCD
        _delay_ms(50); // delay of 50 mili seconds
        LCD_write_string("ABC");
   else
         DDRB=0xff;
         DDRD=0x07;
         init_LCD();
         _delay_ms(50);
         LCD_write_string("Thank you");
return 0;
Only "completely" wrong is the first if "//Check high on pin0 of portA". You are assigning a value 0x01 to PORTA and therefore the statement is always true. The correct way is to do bitwise AND with a bitmask and the port value.
When reading port A value, you read from the register PINA (no from PORTA).
Below is the right code. I assume that PINA0 is just a macro for the pin number.
/* Check high on pin0 of portA */
if(PINA & (1<<PINA0))
You should take initializations out from the while loop and call them only once at the beginning of the program:
C:
int main()
      if(PINA & (1<<PINA0))//Check high on pin0 of portA
   else
         _delay_ms(50);
return 0;
What programming environment are you using? Are you using avr-gcc and avr-libc?
Thanks for your reply sir. :)
I corrected the program statement to if(bit_is_clear(PINA,0)) //Check pin0 of portA
It worked sir.
"You should take initializations out from the while loop and call them only once at the beginning of the program"- Sir before it worked normally but after i removed initialization out of loop i am getting weird results on LCD display. I have attached the pictures of before and after display of LCD.
Picture-1 represents the LCD initialization done outside the loop and Picture-2 represents the LCD initialization done inside the loop.
Between i use AVR GCC sir.
When you write to the LCD the cursor stays at the end of last string you wrote.. in this case at the end of "Than you". Next time you write to the LCD the text is written starting from the place where you left the cursor.. in this case "Thank youThank you". You need to clear the LCD before each write. Clearing the LCD also moves the cursor at the beginning. Initializing the LCD clears it and moves the cursor at the beginnin, but also does some other stuff which are unnecessary.
Try something like:
C:
int main()
        LCD_clear(); // Clear the LCD and move cursor to position (0,0)
   else
         _delay_ms(50);
return 0;
The LCD_clear() function can be named differently.. check your LCD library for correct function.
Thank you so much sir. :)
I got the output correctly.
However while building the program i got 3 warnings . Does it matters ?
I have posted the warnings along with the code below. Please let me know the changes if possible.
../Test3-lcd.c:37: warning: implicit declaration of function 'LCD_write_string'
../Test3-lcd.c:89: warning: conflicting types for 'LCD_write_string'
../Test3-lcd.c:37: warning: previous implicit declaration of 'LCD_write_string' was here
Code
//LCD Program/*
//LCD DATA port----PORT B
//signal port------PORT D
// rs-------PD0
// rw-------PD1
// en-------PD2 */
#define F_CPU 16000000UL
#include<avr/io.h>
#include<util/delay.h>
#define LCD_DATA PORTB //LCD data port
#define ctrl PORTD
#define en PD2 // enable signal
#define rw PD1 // read/write signal
#define rs PD0 // register select signal
void LCD_cmd(unsigned char cmd);
void init_LCD(void);
void LCD_write(unsigned char data);
int main()
DDRA = 0b00000000; //configure portA as input
DDRC= 0xff; //Configure portC as output
while(1)
if(bit_is_clear(PINA,0)) //Check high on pin0 of portC
PORTC&=~(1<<PINC0); // turn off buzzer
LCD_cmd(0x01); // clear LCD
else
PORTC|= 1<<PINC0; //Turn on buzzer
LCD_write_string("Buckle up");
return 0;
void init_LCD(void)
LCD_cmd(0x38); // initialization of 16X2 LCD in 8bit mode
_delay_ms(1);
_delay_ms(1);
LCD_cmd(0x0E); // cursor ON
_delay_ms(1);
LCD_cmd(0x80); // ---8 go to first line and --0 is for 0th position
_delay_ms(1);
return;
LCD_DATA=cmd;
ctrl =(0<<rs)|(0<<rw)|(1<<en);
_delay_ms(1);
ctrl =(0<<rs)|(0<<rw)|(0<<en);
_delay_ms(50);
return;
LCD_DATA= data;
ctrl = (1<<rs)|(0<<rw)|(1<<en);
_delay_ms(1);
ctrl = (1<<rs)|(0<<rw)|(0<<en);
_delay_ms(50);
return ;
void LCD_write_string(unsigned char *str) //store address value of the string in pointer *str
int i=0;
while(str!='\0') // loop will go on till the NULL character in the string
LCD_write(str); // sending data on LCD byte by byte
i++;
return;
You have to declare all your functions. After these lines:
add the missing function declaration:
void LCD_write_string(unsigned char *str);
Sir i am very new to these stuff. If you don't mind could you please elaborate ?
This part of the code:
C:
int main()
...etc
should be:
C:
void LCD_write_string(unsigned char *str);  // ADD THIS LINE
int main()
...etc
Those lines are called "function declarations" and they tell the compiler that these functions are somewhere.. simply put, I hope.
C:
int main()
...etc
should be:
C:
int main()
...etc
Thanks for the info sir.
Sir i got that problem solved but got two new warnings at
../Test3-lcd.c:37: warning: pointer targets in passing argument 1 of 'LCD_write_string' differ in signedness
../Test3-lcd.c:45: warning: pointer targets in passing argument 1 of 'LCD_write_string' differ in signedness
_delay_ms(50);
LCD_cmd(0x01); // This line warning
else
_delay_ms(50);
You marked the wrong lines red. The warning come from the lines where you call the function LCD_write_string("Thank you"); and LCD_write_string("Buckle up");.
You can fix this by changing the input parameter of that function to char *str
void LCD_write_string(char *str);
Make the change to the declaration and to the function definiton itself.
C:
/* Declaration of the function */
void LCD_write_string(char *str); //CHANGE THIS
/* Definition of the function */
void LCD_write_string(char *str)	//CHANGE THIS
    int i=0;
    while(str[i]!='\0')	 // loop will go on till the NULL character in the string
        LCD_write(str[i]);	 // sending data on LCD byte by byte
        i++;
    return;
Make the change to the declaration and to the function itself.
C:
/* Implementation of the function */
    int i=0;
        i++;
    return;
It worked sir.Thanks a ton .:) You really helped me a lot.
Sir i have very little knowledge about this and can't always trouble everyone in this forum.
Can you suggest me a link where i can learn about these stuff i.e. programming?
It is hard to find really good stuff for learning C for microcontrollers.. All the good books and websites are for desktop computers. But it still is the same language. You just can't use some features in a microcontroller (like dynamic memory allocation etc.)
Here is a pretty good site.. well organized.
