    Dismiss Notice
Problem saving variables?
Discussion in 'Microcontrollers' started by Rod Harty, Aug 4, 2017.
  1. Rod Harty
    Rod Harty New Member
    Aug 4, 2017
    2
    0
    I'm using a Mplab IDE v8.92 compiler. I can assign a variable to a value:
    movlw b'00000111'
    movwf var1 ;initialize var1
    the watch box shows that the memory position (in this case, 0x20) holds the correct value.
    However, when I retrieve the value;
    clrw
    movlw var1
    the work register shows the memory position, not the value contained.
    Ideas?
  2. jpanhalt
    jpanhalt Well-Known Member Most Helpful Member
    Jun 21, 2006
    5,886
    500
    Cleveland, OH, USA
    If you show your whole code it will help. One of the "gottchas" of Assembly is the movlw instruction. It will return the register location, which BTW is very useful for setting up indirect addressing. Try, "movf register,w"
    John
  3. Rod Harty
    Aug 4, 2017
    2
    0
    That works, Thank you,
Share This Page
