    Dismiss Notice
Problem in sending SMS through GSM module using 8051
Discussion in '8051/8951' started by Bob Parihar, Apr 29, 2015.
  1. Bob Parihar
    Bob Parihar Member
    Oct 8, 2014
    87
    0
    iam doing a project on sms sending through gsm
    using SIM 900 module and 8051
    My code is:
    #include<reg51.h>
    unsigned char *command = "AT";
    unsigned char *echo = "ATE0";
    unsigned char *msgConfig = "AT+CMGF=1";
    unsigned char *number = "AT+CMGS=\"8283******\"";
    unsigned char *message = "hello";
    unsigned char CTRLZ = 0x1A; // now as a variable
    void serial_init(void);
    void serial(unsigned char);
    void puts(unsigned char *p );
    void delay(void);
    void main()
    serial_init();
    puts(command);
    serial(0x0D); // /r after each command
    delay(); // delay of approx 1 sec
    puts(echo);
    serial(0x0D);
    delay();
    puts(msgConfig);
    serial(0x0D);
    delay();
    puts(number);
    serial(0x0D);
    delay();
    puts(message);
    serial(0x0D);
    delay();
    serial(CTRLZ); //editing here
    while(1);
    TMOD=0x20; //timer 1, mode 2(8-bit autoreload) to set baud rate
    TH1=0xFD; //-3 to TH1 for 9600 baud rate
    SCON=0x50; // 8 bit txion, 1 start 1 stop bit, REN enable for both txfr and rxve
    TR1=1; // start timer
    void puts(char *p)
    char *temp = p; /*temp pointer so that the actual pointer is not displaced */
    while(*temp != 0x00)
    serial(*temp);
    temp++;
    void serial(unsigned char x)
    SBUF=x;
    while(TI==0);
    TI=0;
    void delay(void) // delay for approx 1 sec
    int i;
    TMOD=0x01; // timer 0 in mode 1
    for(i=0;i<142;i++)
    TL0=0x00; // starting value from 0
    TH0=0x00;
    TR0=1; // sart timer
    while(TF0==0); // polling TF flag for high
    TR0=0; // stop timer
    TF0=0; // clear flag TF0
    the problem here is SMS won't send by the GSM
    when i use the calling function by replacing the AT commands then calling works
    but SMS won't.. i think iam wrong in sending AT commands for SMS... please correct me
  2. Tony Stewart
    Tony Stewart Well-Known Member Most Helpful Member
    Aug 31, 2012
    3,151
    281
    Richmond Hill , ON Canada near Toronto
    Does SMS need CR or LF?
  3. Wp100
    Wp100 Active Member
    Feb 3, 2009
    959
    43
    England
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. Tony Stewart
    Aug 31, 2012
    3,151
    281
    There are AT commands to delimit either or both, so I assume that was done.
  6. Bob Parihar
    Bob Parihar Member
    Oct 8, 2014
    87
    0
    im not getting you
  7. Bob Parihar
    Bob Parihar Member
    Oct 8, 2014
    87
    0
  8. Tony Stewart
    Aug 31, 2012
    3,151
    281
    Delimiters separate one parameter from the next - they split the command line up into words.
  9. Cicero
    Cicero Active Member
    Nov 21, 2014
    335
    36
    UK
    He is sending a CR after each line, separately, so its all good there.
    I suspect it may be the final CTRLZ maybe?
    Code (text):
    unsigned char *CTRLZ = 0x1A;
    puts(CTRLZ);
    That doesn't send the 0x1A, you're sending the address. Try removing the pointer, unsigned char CTRLZ = 0x1A;
    EDIT: Actually I'm wrong here, CTRLZ does contain 0x1A, its just declared as a pointer though. Which isn't quite right.
  10. Bob Parihar
    Bob Parihar Member
    Oct 8, 2014
    87
    0
    removed pointer...and i used variable... doesn't work
  11. Cicero
    Nov 21, 2014
    335
    36
    UK
    EDIT: Please see response below.
  12. Cicero
    Nov 21, 2014
    335
    36
    UK
    Theres also a problem with your puts routine.
    Code (text):
    void puts(char *p)
    serial(*temp);
    temp++;
    This is only really for sending a string, because its waiting for your null character at the end. If you try send a single unsigned char like CTRLZ, it isn't a string, so it may not have a NULL after it, and it'll just increase its address and send random data until it finds one.
    Rather send CTRLZ using your serial function, like you do for your 0x0D.
    And actually, looking at the Arduino code, you will have to add in LF characters after all - you only send CR's.
    Here's the Arduino code:
    Code (text):
    void sendSMS(String message)
      SIM900.print("AT+CMGF=1\r");                     // AT command to send SMS message
      delay(100);
      SIM900.println("AT + CMGS = \"+12128675309\"");  // recipient's mobile number, in international format
      delay(100);
      SIM900.println(message);                         // message to send
      delay(100);
      SIM900.println((char)26);                        // End AT command with a ^Z, ASCII code 26
      delay(100);
      SIM900.println();
      delay(5000);                                     // give module time to send SMS
      SIM900power();                                   // turn off module
    println() prints both a CR and a LF character. Notice you only print a CR. Also, after printing the 0x1A, there's also a CRLF, and another CR LF when it sends a blank SIM900.println();
  13. Ian Rogers
    Ian Rogers Super Moderator Most Helpful Member
    Mar 28, 2011
    9,164
    910
    Rochdale UK
    You have been given false info.... CTRLZ was fine as a pointer but it needed referencing as puts accepts a pointer.
    puts(CTRLZ);
    Should have been..
    puts(*CTRLZ);
    EDIT** Sorry..... but you will also have to NULL terminate...
    Its best to use
    serial(0x1A);
  14. Cicero
    Nov 21, 2014
    335
    36
    UK
    Actually you're wrong Ian. I admitted I was slightly mistaken.
    Please reread my posts, and the edits.
  15. Ian Rogers
    Mar 28, 2011
    9,164
    910
    Rochdale UK
    I know I know... I have just realized myself...
    The CTRLZ should be used as you said.... I missed that post for some reason....
    I was wrong as well with my second statement.... If he had just terminated the CTRLZ string with a NULL all this would be academic....
  16. Cicero
    Nov 21, 2014
    335
    36
    UK
    True, that would be fine.
    It confused me (clearly) as well. As I understand it now...
    CTRLZ we agree was a pointer. But as a pointer, it was assigned to 0x1A. So CTRLZ was in fact 0x1A. However, *CTRLZ was whatever is at address 0x1A - probably an access violation. Just feels a bit messy.
    Like you said, he could've just gone:
    Code (text):
    unsigned char CTRLZ[] = {0x1A, 0x00};
    And it would've been fine as well. Although I'm sure he needs LF's and CR's everywhere to match that Arduino tutorial.
  17. Bob Parihar
    Bob Parihar Member
    Oct 8, 2014
    87
    0
    sir, i edited like you suggested... see the code above
    but still got negative results
  18. Cicero
    Nov 21, 2014
    335
    36
    UK
    Repost your updated code please
  19. Bob Parihar
    Bob Parihar Member
    Oct 8, 2014
    87
    0
    #include<reg51.h>
    void delay(void);
    void main()
    serial_init();
    puts(command);
    puts(echo);
    serial(0x0D);
    delay();
    puts(msgConfig);
    serial(0x0D);
    delay();
    puts(number);
    serial(0x0D);
    delay();
    puts(message);
    serial(0x0D);
    delay();
    while(1);
    void puts(char *p)
    serial(*temp);
    temp++;
    SBUF=x;
    while(TI==0);
    TI=0;
    int i;
    for(i=0;i<142;i++)
    TH0=0x00;
  20. Cicero
    Nov 21, 2014
    335
    36
    UK
    Yeah, you still haven't added any LF characters? You've only changed the pointer issue.
    Another thing in the Arduino code, is that the number is in international format...not sure if thats necessary?
    Try the code below which follows the Arduino code virtually as close as possible.
    Code (text):
    #include<reg51.h>
    unsigned char *number = "AT + CMGS =\"8283******\"";
    void delay(void);
    void main()
    serial_init();
    /* Not running this as its not in the Arduino code */
    #ifdef ECHO_CMD
      puts(command);
      puts(echo);
      serial(0x0D);
      delay();
    #endif
    puts(msgConfig);  // SIM900.print("AT+CMGF=1\r");
    serial(0x0D);
    delay();
    puts(number); // SIM900.println("AT + CMGS = \"+12128675309\"");
    serial(0x0D);
    serial(0x0A);
    delay();
    puts(message); //SIM900.println("Hello, world. This is a text message from an Arduino Uno.");
    serial(0x0D);
    serial(0x0A);
    delay();
    serial(CTRLZ); // SIM900.println((char)26);
    serial(0x0D);
    serial(0x0A);
    delay();
    serial(0x0D); // SIM900.println();
    serial(0x0A);
    while(1);
    void puts(char *p)
    serial(*temp);
    temp++;
    SBUF=x;
    while(TI==0);
    TI=0;
    int i;
    for(i=0;i<142;i++)
    TH0=0x00;
  21. Bob Parihar
    Bob Parihar Member
    Oct 8, 2014
    87
    0
    not getting what you have edited..
    after each command i added LF Characters
    serial(0x0D); // /r
    serial(0x0A); // /n
Share This Page
