plz help meeeeeee
muralistarshine
i was working with 89c51 and i have to set the bit p1.4 for both of the bits p2.3 and p2.4 on
if only p2.3 i have to set bit p1.3
i need to implement as model to execute my project work can above program can be done on hardware???????
org 0000h
back:
jb p2.3,led1
sjmp back
led1:
jb p2.4,led2
setb p1.3
led2:
setb p1.4
end
plz help meeeee
Why did you create a new post on the same subject, where people have already answered you? This is worst than double posting.
You mean
a) P2.3 and P2.4 ON = Set P1.4
b) P2.3 ON = Set P1.3
right?
I see multiple problems on your code:
1) It runs only once since there's no endless loop
2) Both P1.3 & P1.4 will always be ON since there's no jump after setting P1.3
3) You never reset P1.3 & P1.4 is that normal?
Beside what Hayato mentioned in your other thread regarding the same problem this would be fine.
Loop:
JNB P2.3, ResetAll
SETB P1.3
JNB P2.4, Loop
SETB P1.4
JMP Loop
ResetAll:
CLR P1.3
CLR P1.4
JMP Loop
Gee, that's a looooooooooooooooooooooong time I ever wrote ASM code :)
modify mr. rushi53 code use as switch
for me , i modify rushi53rushi53 code to use as switch p2.3 and p2.4 if pressed mean 0 , if release mean 1 . circuit input connect 100k resistor to port 2.3 and port 2.4 , each port 2.3 and 2.4 connect to a switch then to ground(GND).
for output led , cathode connect to a 330 ohm resistor anot connect to 5v VCC.
            org 0000h
	    setb p2.3
	    setb p2.4
back:       jnb p2.3,ledp13on
            clr p1.3
            clr p1.4
            sjmp back
ledp13on:   jnb p2.4,ledp14on
            setb p1.3
            clr p1.4
            sjmp back
ledp14on:   setb p1.3
            setb p1.4
            sjmp back
            end
the led on when :-
p2.3=0 ,p1.3 led on
p2.3 & 2.4 =0 ,p1.3 & 1.4 led on
switch pressed = 0
switch release(no press) = 1
comment if something wrong i will reply as soon as possible
            org 0000h
	    setb p2.3
	    setb p2.4
            clr p1.3
            clr p1.4
            sjmp back
            setb p1.3
            clr p1.4
            sjmp back
ledp14on:   setb p1.3
            setb p1.4
            sjmp back
            end
the led on when :-
p2.3=0 ,p1.3 led on
switch pressed = 0
This is what your code does:
Switch 2.3 unpressed:
LED 1.3 = ON
LED 1.4 = ON
Switch 2.3 pressed:
LED 1.3 = ON
LED 1.4 = ON
Switch 2.4 pressed:
LED 1.3 = ON
LED 1.4 = ON
Why, do you ask.
Because you are always going back to the "back" loop.
Lets summarize:
1.3 = 0 -> LED1 ON
1.3 = 1 -> LED1 OFF
1.4 = 0 -> LED2 ON
1.4 = 1 -> LED2 OFF
2.3 = 0 -> SW1 PRESSED
2.3 = 1 -> SW1 UNPRESSED
2.4 = 0 -> SW2 PRESSED
2.4 = 1 -> SW2 UNPRESSED
Conditions mentioned by the OP
SW1 PRESSED -> ONLY LED1 ON
SW1 & SW2 PRESSED -> ONLY LED2 ON
 org 0000h
	    setb p2.3 ;INPUT
	    setb p2.4 ;INPUT
	    setb p1.3 ;TURN LED1 OFF
	    setb p1.4 ;TURN LED2 OFF
START: jnb p2.3,ledp13on ;if SW1 pressed, goto ledp13on
            jnb p2.4,ledp14on ;if SW2 pressed, goto ledp14on
            sjmp START
ledp13on:jnb p2.4,ledp14on ;if SW2 pressed, goto ledp14on else turn LED1 ON only
              clr p1.3
              setb p1.4
              sjmp START
ledp14on:jb p2.3, START ;IF SW2 = pressed and SW1 = unpressed, nothing happens, else turn LED1 &2 ON
              clr p1.3
              clr p1.4
              sjmp START
              end
Don't forget the debounce routines, and to initializate the uC.
