Please help, what does gt abbreivation mean pcb what is the components name?
Billy1234510
Hi everyone,
I've never posted to forums before but basically I have a pcb from a soundbar, I believe I have tracked down the problem, I'm an absolute novice so I may be completely wrong, it appears to be a zener diode to me, but it has no part number to order a new one, the only information I have is gt900 written on the pcb from where I removed the component.
Please see pictures one is of component the other is of the board.
I have no idea for gt stands for so please help so I can possibly order a new one and than retest the board once its in place.
Thanks in advance.
Welcome to ETO!
My guess is it's an over-voltage spark gap, judging by the symbol on the pcb and its position close to what looks like a common-mode choke at the circuit mains supply input.
What makes you think it is faulty?
Welcome to ETO!
Because I thought it was a diode and when plugged in it had no voltage going through it either way, also in and out of the circuit it had no continuity, there was power to what I thought was a transformer of sort, the copper thing I'm guessing is the component you're referring to as a common mode choke?
P.s thanks for speedy reply.
Can't you put the original part back? Your meter readings are what would be expected for a good component.
...and just for your information your device should work without it, if it isn't, you have further problems.
Yeah I need to inspect the other diodes, I did think when it was mentioned what it was I was thinking couldn't I just put a jumper in but didn't want to sound too idiotic
Are you sure that a jumper will not alter things?
Check this link and press "Like button" if this post is usefull...
Regards Manoj
Upon checking that site you look very much correct in your analysis of what it is, one stupid question so forgive me but I take it as its a normal 240v in power supply it will require the 160-240v but how do I know which current and capacitance value I should get? Thanks in advance
The site shows...
SCB-251M
Packaging: Voltage:250(200~300)V
Current:1000A Clamp Voltage:
Capacitance:1.0pF Power:
