PIC16F818 int config
TKS
hi, i was wondering how i could
set the internal config bits to 8MHz..
the data spec says that you have to set 111 to bit 7 to 5 but i have no idea how to do this..
i want to do this when i program the device soow not when i'm in code.
TKS
TKS
You simply write that value to the OSCCON register, it's fully explained in the datasheet. You have to do this in your program code (only two lines), you can't do it from the programmer - although you must set the config fuses (in the programmer) to use the internal oscillator.
movlw b'01110000'
movwf OSCCON
It's as easy as that!.
