Pic12f629 Ports Problem.
bitem2k
Hi, Ive turned off the Comparator module on the 629,
changed trisio to 0x00,
and now i can change the first 3 bits of GPIO register to 1.
I know you cant use GP3 as an output, but I still cant change GP4 or GP5 bits of the GPIO register to 1.
Ive searched the datasheet for ages, but I cant seem to find anything else to turn off, to allow me to use GP4 and 5:mad:.
Any ideas?
Ive just burned the program onto the pic, and it works!
For some reason MPLAB SIM is not letting me change the register, but the Actual PIC will.
Any ideas?
You can create a Simulation file. The instructions can be found using Help->MPLAB Sim. I never use them, can I get confirmation from someone here?
Where and when are you attempting to change the register? During the sim debug (F7) wait till the trisio is completed (or after the port pin is an Output). Also when using the SFR View box, add a Binary column to the table and change the exact GP bit
Edit:
This worked another device. I have same issue with 12629.
Your ports input/output selecting routine must like this after switching to bank1 & before calling OSCCAL value if have.
	movlw	b'001000'	;GP3 input
	movwf	TRISIO
To make all outputs high except GP3
	movlw	b'110111'
	movwf	GPIO
dont set bits like this continuously
	bsf	GPIO,4
	bsf	GPIO,5
do like this
	movlw	b'110000'	;turn ON bit 4 & 5
	movwf	GPIO
yes I had done all that, still gives incorrect reading in sim.
Oh well, cant be arsed anymore.
thanks anyway.
I suspect that you havn't told MPLAB that you want to use the internal oscillator. Try changing the config settings.
Edit:
Edit Again:
This now works with then 12F629. No change to file or project. For some reason it worked the next day! Internal RC No Clock Out is configured just as it was yestarday. What gives?
Ive not got a new problem.
I cant seem to get GP1 to go high.
This makes my allready meagre looking, 5 led knight rider light look even crapper;)
Heres my code
;KNIGHT RIDER THINGY
LIST P=PIC12F629
include "P12F629.inc"
    __CONFIG   _CP_OFF & _CPD_OFF & _BODEN_OFF & _MCLRE_OFF & _WDT_OFF & _PWRTE_ON & _INTRC_OSC_NOCLKOUT
CBLOCK 0x20
SUBCOUNT
COUNT
LEDPORT
ENDC
PROGSTART
    ORG        0x0000
SETUP_OSC
    DELAYTIME     EQU D'100'
    bsf STATUS, RP0 ;Bank 1
    call 3FFh ;Get the cal value
    movwf OSCCAL ;Calibrate
    bcf STATUS, RP0 ;Bank 0
SETUP
    BSF     STATUS,RP0    ;CHANGE TO BANK1
    MOVLW    0x00        ;SET W REGISTER
    MOVWF    TRISIO        ;SET ALL PORTS TO OUTPUT
    BCF     STATUS,RP0    ;CHANGE TO BANK0
    CLRF     GPIO        ;CLEAR GPIO REG
    MOVLW    B'111'        ;DISABLE
    MOVWF   CMCON        ;COMPARATOR
START
    MOVLW    0x01        ;TURN first port
    MOVWF     LEDPORT        ;SET LEDPORT
    CALL     SYNCGPIO    ;MOVE LEDPORT INTO GPIO
    MOVLW    DELAYTIME    ;LOAD DELAY TIME INTO W
    CALL     DELAY        ;CALL THE DELAY ROUTINE
    GOTO    MOVELEFT    ;START MOVING BITS (LEDS) LEFT
SYNCGPIO
    MOVFW    LEDPORT        ;COPY LEDPORT BITS
    MOVWF    GPIO        ;INTO THE GPIO REGISTER
    RETURN
MOVELEFT
    RLF        LEDPORT, F    ;SHIFT BIT LEFT(I.E LED)
    ;CHECK IF NEXT PORT IS GP3
    BTFSC    LEDPORT, GP3;SKIP NEXT LINE IF ZERO
    RLF     LEDPORT,F    ;SKIP THIS PORT(GP3) SHIFT BIT LEFT(I.E LED)
    MOVLW    DELAYTIME    ;SET DELAY TIME
    CALL     DELAY
    BTFSC    LEDPORT, 5    ;CHECK IF WE ARE AT THE LEFTMOST POSITION
    GOTO    MOVERIGHT    ;IF WE ARE AT LEFTMOST POS START MOVING RIGHT AGAIN
    GOTO     MOVELEFT    ;MOVE LED LEFT AGAIN
MOVERIGHT
    RRF        LEDPORT, F    ;SHIFT BIT RIGHT(I.E LED)
    RRF     LEDPORT,F    ;SKIP THIS PORT(GP3) SHIFT BIT RIGHT(I.E LED)
    CALL     DELAY
    BTFSC    LEDPORT,GP0    ;CHECK IF WE ARE AT RIGHTMOST POSITION.
    GOTO     START        ;GO BACK TO THE BEGINNING
    GOTO     MOVERIGHT    ;MOVE LED RIGHT AGAIN
DELAY
    MOVWF    COUNT        ;LOAD VALUE # OF LOOPS FROM W REGISTER
DELAYLOOP
    DECFSZ    SUBCOUNT
    GOTO DELAYLOOP
    DECFSZ    COUNT
    GOTO DELAYLOOP
    RETURN
end
Any ideas?
many thanks:)
Your not clearing the carry flag before the first shift. Try,
MOVELEFT
    BCF        STATUS,C
And the same on MoveRight.
Nice one mate, thanks once again.
Ive read the datasheet, but i dont really understand why this makes a difference. could you explain that to me please.
Pics are very difficult to blow. Are you using current limiting resistors? Is your supply less than 5.5V? Does your pic get hot? Can you post a schematic?
I agree, PIC's are VERY hard to damage, I've never managed it yet :D but I've got one that got so hot it's got my fingerprint burnt in the top! (don't put them in the socket the wrong way round!).
