Pic debounce routine
OK.
This is the code.
For the main loop:
main_loop:
	movf	temper,W		; Put temperature in W
	call	bin2bcd			; Decode Temperature to bcd
	movf	units,W			; copy units to W
	call	decdisp_a		; convert
	bsf		LED_CMN			; Leds off
	movwf	PORTA			; put it in PORTA
	call	decdisp_b		; convert
	movwf	PORTB			; put it in PORTA
	bcf		DISP1			; display 1 on
	call	H_keeping		; delay 2 ms
	movf	tens,W			; copy tens to W
	bsf		DISP1			; display 1 off
	bcf		DISP2			; display 2 on
	movf	hundreds,W		; copy hundeds to W
	bsf		DISP2			; display 2 off
	bcf		DISP3			; display 3 on
	bsf		DISP3			; display 3 off
	; Leds code:
	bsf		LEDS_ON			; Flag leds on
	bcf		LED_CMN			; Leds on
	goto	main_loop		; Back to main loop
for the housekeeping:
H_keeping:
    ; Leds:
    ;   7       6       5       4       3       2       1       0
    ; blink   onoff     up     down   light    toast   time    temp
    btfss	leds_s,7	; Is led blink enabled?
    goto	contled		; not enabled    ; No, get out!
    btfsc	leds_s,6	; Is led on/off on?
    goto	$+3
    bcf		LED_ONOFF	; No - it's activated directly, not using LED_CMN
    goto	$+2
    bsf		LED_ONOFF	; Yes - it's activated directly, not using LED_CMN
;notenabled:
    decfsz	Led_blink,F	; Blink control = 0?
    goto	contled		; No
    movlw	D'255'		; Value to preload to
    movwf	Led_blink	; Led blink time control
    goto	setledoff
    bsf		leds_s,6	; Led on/off in on
    goto	contled
setledoff:
    bcf		leds_s,6	; Led on/off in off
contled:
    btfss	LEDS_ON
    goto	endleds
    btfsc	leds_s,5	; Is led up on?
    goto	$+3
    bsf		LED_UP		; No
    goto	$+2
    bcf		LED_UP		; Yes
    btfsc	leds_s,4	; Is led down on?
    goto	$+3
    bsf		LED_DWN		; No
    goto	$+2
    bcf		LED_DWN		; Yes
    btfsc	leds_s,3	; Is led light on?
    goto	$+3
    bsf		LED_LIGHT	; No
    goto	$+2
    bcf		LED_LIGHT	; Yes
    btfsc	leds_s,2	; Is led toast on?
    goto	$+3
    bsf		LED_TOASTER	; No
    goto	$+2
    bcf		LED_TOASTER	; Yes
    btfsc	leds_s,1	; Is led time on?
    goto	$+3
    bsf		LED_timer	; No
    goto	$+2
    bcf		LED_timer	; Yes
    btfsc	leds_s,0	; Is led temp on?
    goto    $+3
    bsf		LED_TEMP	; No
    goto	$+2
    bcf		LED_TEMP	; YES
endleds:
    bcf		LEDS_ON
    ; Test_Keys (k_pressed):
    ;   7       6       5       4       3       2       1       0
    ;   X      up     timer   onoff    light   toast   temp    down
    bsf		STATUS,RP0	; Bank 1
	;bcf    STATUS,RP1	;  "   "
    bcf		OPTION_REG,NOT_RABPU ; Activate pull-up resistors - Clear RABPU flag
    movlw	B'00111100'	;
    movwf	TRISA		; Make RA2, RA4, RA3 and RA5 inputs (RA3 is a sensor)
    movlw	B'11110000'	;
    movwf	TRISB		; Make RB4, RB5, RB6 and RB7 inputs
    movlw	B'00110100'	;
    movwf	WPUA		; Enable RA2, RA4 and RA5 pull-up internal resistors
    bcf		STATUS,RP0	; Bank 2
	bsf		STATUS,RP1	;  "   "
    movlw	B'11110000'
    movwf	WPUB		; Enable RB4, RB5, RB6 and RB7 pull-up internal resistors
    bsf		STATUS,RP0	; Back to Bank 1
	bsf		OPTION_REG,7	; Set RABPU flag
    bcf		STATUS,RP0		; Bank 0
    btfss	KEY_UP			; KEY_UP pressed?
    incf	temper,F		; Yes
    btfsc	KEY_UP			; Key Up pressed?
    goto	$+3				; No
    bsf		k_pressed,6		; Yes, set flag
    goto	$+2				; Exit
    bcf		k_pressed,6		; No, reset flag
    btfsc	KEY_timer		;
    goto	$+3				;
    bsf		k_pressed,5		;
    goto	$+2				;
    bcf		k_pressed,5		;
    btfsc	KEY_ONOFF		;
    goto	$+3				;
    bsf		k_pressed,4		;
    goto	$+2				;
    bcf		k_pressed,4		;
    btfsc	KEY_LIGHT		;
    goto	$+3				;
    bsf		k_pressed,3		;
    goto	$+2				;
    bcf		k_pressed,3		;
    btfsc	KEY_TOASTER		;
    goto	$+3				;
    bsf		k_pressed,2		;
    goto	$+2				;
    bcf		k_pressed,2		;
    btfsc	KEY_TEMP		;
    goto	$+3				;
    bsf		k_pressed,1		;
    goto	$+2				;
    bcf		k_pressed,1		;
    btfsc	KEY_DWN			;
    goto	$+3				;
    bsf		k_pressed,0		;
    goto	$+2				;
    bcf		k_pressed,0		;
    bcf		WPUA,7
    bcf		WPUB,7
    bcf		OPTION_REG,7	; Set RABPU flag
    movlw	B'00001000'		;
    movwf	TRISA			;
    movlw	B'00000000'		;
    movwf	TRISB			;
    retlw    00
Now, with the correct paging for the WPUB register, the value in display continues to update while the key up is pressed, without problems.
The flashing rate is increased (almost twice a seond, because there were the timming inside the beep routine which is gone) and we are at the limit for the counter in Led_blink file.
Another thing: while the key is pressed and the display is being updated, the leds which were suposed to be off , blinks.
1. Add a small "do-nothing" delay in housekeeping to get the blink correct and when you add more instructions to H_Keeping, you can reduce this delay.
2. Another thing: while the key is pressed and the display is being updated, the leds which were suposed to be off , blinks.
Which key? what update?
3. bcf LEDS_ON ; you have to comment on each instruction because I have absolutely no idea what is happening because most of this is negative logic. And when you come back to it later, YOU won't know what is happening either.
4. To get into bank 2 you have to set RP1 NOT RP0
I will do the nop timing.
To test the keys, I test the key_up and, if pressed, I just increment the temper file (temperature) which is updated in display during the first to third parts of SCAN.
    incf	temper,F		; Yes
Ok, I will comment more.
Ok, but isn't:
RP0 RP1 BANK
0 0 0
0 1 1
1 0 2
1 1 3
So, as I am in bank 1, if I just sets RP1, I will be in bank 3, not bank 2.
I just added another file (aux_file) and this code to the house keeping, so, now, the display bright is ok.
    decfsz	aux_file,F
    goto    $-1
Just to help, one of the leds is on, when it should be off and 2 leds (in reality all, because the others are on and you can't see), are blinking when the key up is pressed and the display is being updated.
I have put one movie in youtube, to see what is going on.
The lower right led should be off;
The leds should not be blinking while the display is updated.
You can see a small movie (6 seconds) at:
YouTube - MVI_0893.avi
1. To get in to bank 2 you have to finish with bank 1 and get back into bank then bsf RP1 your instructions were correct but your comments were wrong and that's what messed me up. GET YOUR COMMENTS CORRECT.
2. Load aux_file with a value so you can reduce it later.
I don't know what LEDs should be on and what should be off, so the video is not use to me.
Just explain clearly what is happening. It looks the display should be incremented more slowly.
The leds wich should be off are the 2 in the bottom (light and toaster) and the left one (timeset).
This can be seen in the start of the code:
	movlw	B'11110001'		; Leds initial state (led onoff blinking, up, down and temperature on)
	movwf	leds_s			; Set leds state
The display should be incremented more slowly, yes, but we need to work the debounce / autoincrement code, as you said before.
I need to see the full code as you have used negative logic
The guy who projected the circuit used negative logic - I would never done that.
The code is:
;* DESCRIPTION: System definitions.
	ERRORLEVEL -302 ;remove message about using proper bank
	LIST  P=16F677
	INCLUDE <P16F677.INC>
	__CONFIG _BOR_OFF & _FCMEN_OFF & _IESO_OFF & _CPD_OFF & _CP_OFF & _MCLRE_OFF & _PWRTE_ON & _WDT_OFF & _INTOSCIO
;* DESCRIPTION: Program variables and constant definitions.
temper		equ 0x20						; Store temperature
units		equ 0x24						; units
tens		equ	0x25						; tens
hundreds	equ 0x26						; hundreds
aux			equ	0x27						; GENERAL aux. REGISTER
tempo0		equ	0x28
tempo1		equ	0x29
flags		equ	0x2B						; General use flags
timer		equ	0x2D						; Timer register
buz_file	equ 0x2E						; Buzzer file
buz_length	equ 0x2F						; Buzzer length
leds_s		equ	0x30						; Leds state
k_pressed	equ	0x31						; Keys pressed state
Key_deb		equ	0x32						; Keys debounce flag
Key_off		equ	0x33						; Key off flag
Led_blink	equ	0x34						; Led blink time - for debounce
aux_file	equ	0x35						; timing auxiliar file
sw_flag		equ	0x35						; For keys routines
fastcount	equ	0x36						; For keys routines
#define		LEDS_ON				flags,0		; Flag to see if the leds should be on
; Leds
#define		LED_CMN				PORTC,2		; Leds Anodes
#define		LED_UP				PORTA,4		; Led UP
#define		LED_timer			PORTB,6		; Led timer
#define		LED_TEMP			PORTB,5		; Led TEMP
#define		LED_DWN				PORTA,2		; Led DWN
#define		LED_LIGHT			PORTB,4		; Led LIGHT
#define		LED_TOASTER			PORTA,5		; Led TOASTER
#define		LED_ONOFF			PORTC,6		; Led ONOFF
#define		TRIS_LED_ONOFF		TRISC,6		; Led ONOFF TRIS
; Displays
#define		DISP1				PORTC,3		; Anode display DIS0
#define		DISP2				PORTC,4		; Anode display DIS1
#define		DISP3				PORTC,5		; Anode display DIS2
; Keys
#define		KEY_UP				PORTB,7		; KEY_UP
#define		KEY_timer			PORTB,6		; KEY_timer
#define		KEY_ONOFF			PORTB,5		; KEY_ONOFF
#define		KEY_LIGHT			PORTB,4		; KEY_LIGHT
#define		KEY_TOASTER			PORTA,5		; KEY_TOASTER
#define		KEY_TEMP			PORTA,4		; KEY_TEMP
#define		KEY_DWN				PORTA,2		; KEY_DWN
; Buzzer
#define		buz					PORTC,0		; Buzzer
;* DESCRIPTION: Start of program.
	ORG		0x0000
	goto	start
;* DESCRIPTION: Decodes value in W register to display segments for PORTA.
;* return:      result in W
decdisp_a:
	addwf   PCL,F		; compute the jump value
						;	|7|6|5|4|3|2|1|0| -	Bits PORTA
						;	|-|-|B|E|-|A|-|-|
	retlw	B'00000000'	;	|-|-|B|E|-|A|-|-| -	0
	retlw	B'00010100'	;	|-|-|B|X|-|X|-|-| -	1
	retlw	B'00000000'	;	|-|-|B|E|-|A|-|-| -	2
	retlw	B'00010000'	;	|-|-|B|X|-|A|-|-| -	3
	retlw	B'00010100'	;	|-|-|B|X|-|X|-|-| -	4
	retlw	B'00110000'	;	|-|-|X|X|-|A|-|-| -	5
	retlw	B'00100000'	;	|-|-|X|E|-|A|-|-| -	6
	retlw	B'00010000'	;	|-|-|B|X|-|A|-|-| -	7
	retlw	B'00000000'	;	|-|-|B|E|-|A|-|-| -	8
	retlw	B'00010000'	;	|-|-|B|X|-|A|-|-| -	9
;* DESCRIPTION: Decodes value in W register to display segments, for PORTB.
decdisp_b:
						;	|7|6|5|4|3|2|1|0| -	Bits PORTB
						;	|C|F|D|G|-|-|-|-| -
	retlw	B'00010000'	;	|C|F|D|X|-|-|-|-| -	0
	retlw	B'01110000'	;	|C|X|X|X|-|-|-|-| -	1
	retlw	B'11000000'	;	|X|X|D|G|-|-|-|-| -	2
	retlw	B'01000000'	;	|C|X|D|G|-|-|-|-| -	3
	retlw	B'00100000'	;	|C|F|X|G|-|-|-|-| -	4
	retlw	B'00000000'	;	|C|F|D|G|-|-|-|-| -	5
	retlw	B'00000000'	;	|C|F|D|G|-|-|-|-| -	6
	retlw	B'01110000'	;	|C|X|X|X|-|-|-|-| -	7
	retlw	B'00000000'	;	|C|F|D|G|-|-|-|-| -	8
	retlw	B'00000000'	;	|C|F|D|G|-|-|-|-| -	9
;* DESCRIPTION: House keeping and delay routine.
H_keeping:
	movlw	D'255'			; Load W with 255 (0xFF)
	movwf	aux_file		; Load aux_file counter with 255
    decfsz	aux_file,F		; Decrement it untill it reaches 0
    goto    $-1				; Keep doing till aux_file is 0
    ; Leds:
    ;   7       6       5       4       3       2       1       0
    goto	$+3
    goto	$+2
    goto	contled			; No
    goto	setledoff		; Yes, turn it off.
    bsf		leds_s,6		; No, turn it on
    goto	contled			; Continue
setledoff:
contled:
    btfss	LEDS_ON			; Are leds enabled? Without this, there were weird display's segments behaviour.
    goto	endleds			; No, get out
    goto	$+3
    bsf		LED_UP			; No
    goto	$+2
    bcf		LED_UP			; Yes
    goto	$+3
    bsf		LED_DWN			; No
    goto	$+2
    bcf		LED_DWN			; Yes
    goto	$+3
    bsf		LED_LIGHT		; No
    goto	$+2
    bcf		LED_LIGHT		; Yes
    goto	$+3
    goto	$+2
    goto	$+3
    bsf		LED_timer		; No
    goto	$+2
    bcf		LED_timer		; Yes
    goto    $+3
    bsf		LED_TEMP		; No
    goto	$+2
    bcf		LED_TEMP		; YES
endleds:
    bcf		LEDS_ON			; Here, I turn on the leds anode (transistor Q6)
    ;   7       6       5       4       3       2       1       0
    bsf		STATUS,RP0		; RP0 = 1 goto Bank 1
    movlw	B'00111100'		; 0 = output - 1 = input
    movlw	B'11110000'		; 0 = output - 1 = input
    movlw	B'00110100'		; 1 = enable pull-up - 0 disable it.
    bcf		STATUS,RP0		; RP0 = 0 -> Bank 2
	bsf		STATUS,RP1		; RP1 = 1 -> "   "
    movlw	B'11110000'		; 1 = enable pull-up - 0 disable it.
    bsf		STATUS,RP0		; RP0 = 1 -> Back to Bank 1
	bcf		STATUS,RP1		; RP1 = 0 -> "   "
    bcf		STATUS,RP0		; RP0 = 0 -> Back to Bank 0 (RP1 already = 0)
    incf	temper,F		; Yes
    goto	$+3				; No
    goto	$+2				; Exit
    btfsc	KEY_timer		;
    goto	$+3				;
    bsf		k_pressed,5		;
    goto	$+2				;
    bcf		k_pressed,5		;
    btfsc	KEY_ONOFF		;
    goto	$+3				;
    bsf		k_pressed,4		;
    goto	$+2				;
    bcf		k_pressed,4		;
    btfsc	KEY_LIGHT		;
    goto	$+3				;
    bsf		k_pressed,3		;
    goto	$+2				;
    bcf		k_pressed,3		;
    btfsc	KEY_TOASTER		;
    goto	$+3				;
    bsf		k_pressed,2		;
    goto	$+2				;
    bcf		k_pressed,2		;
    btfsc	KEY_TEMP		;
    goto	$+3				;
    bsf		k_pressed,1		;
    goto	$+2				;
    bcf		k_pressed,1		;
    btfsc	KEY_DWN			;
    goto	$+3				;
    bsf		k_pressed,0		;
    goto	$+2				;
    bcf		k_pressed,0		;
    bsf		STATUS,RP0		; RP0 = 1 -> Goto Bank 1 (RP1 already = 0)
    bcf		WPUA,7
    bcf		WPUB,7
    movlw	B'00001000'		;
    movwf	TRISA			; Make A0,A1,A2,A4,A5,A6 and A7 outputs.
    movlw	B'00000000'		;
    movwf	TRISB			; Make all PORTB output.
    retlw    00
;* DESCRIPTION: binary_to_bcd - 8-bits
;* INPUT:		temper   - 8-bit binary number
;* return:      hundreds - the hundreds digit of the BCD conversion
;*				tens     - the tens digits of the BCD conversion
;*				units    - the ones digits of the BCD conversion
bin2bcd:
	movwf	aux				; save the value to convert in aux
	clrf	units			;
	clrf	tens			;
	clrf	hundreds		; RESET variables
	movf	aux,F			;
	btfsc	STATUS,Z		; Is the value to convert = 0?
	return					; Yes - Return
							; No
	incf	units,F			; Increment unit
	movf	units,W			;
	xorlw	0X0A			;
	btfss	STATUS,Z		; unit = 10d ?
	goto	$+3				; No
							; yes
	clrf	units			; Reset unit
	incf	tens,F			; Increment tens
	movf	tens,W			;
	xorlw	0X0A			;
	btfss	STATUS,Z		; Tens = 10d ?
	goto	$+3				; No
							; Yes
	clrf	tens			; Reset tens
	incf	hundreds,F		; Increment hundreds
	decfsz	aux,F			; End of convertion ?
	goto	$-.14			; No - go back to continue the convertion
	return					; Yes
;* DESCRIPTION: Program Initialization
start:
	bsf		STATUS,RP1		; RP1 = 1 -> Bank 2
	clrf	ANSEL			; digital I/O
	clrf	ANSELH			;	"	"	"
	movlw	B'00000000'		; To disable comparators
	movwf	CM1CON0			; disable comparator
	movlw	B'00000000'		; Not necessary?
	movwf	CM2CON0			; disable 2nd comparator
	movwf	CM2CON1			; disable 3rd comparator
	bcf		STATUS,RP1		; RP1 = 0 -> Bank 1
	movlw	B'00001000'		; RA0,RA1,RA2,RA4,RA5,RA6 and RA7 output - RA3 input
	movwf	TRISA			; Set it
	movlw	B'00000000'		; All PORTB output
	movwf	TRISB			; Set it
	movlw	B'10000010'		; RC0,RC2,RC3,RC4,RC5,RC6 output - RC1 and RC7 inputs
	movwf	TRISC			; Set it
	bcf		STATUS,RP1		; RP1 = 0 -> Bank 0
	bcf		SSPCON,SSPEN	; Disable Synchronous Serial Port
	; Turn off all displays and leds
	bsf		DISP1			; Display1 off
	bsf		DISP2			; Display2 off
	bsf		DISP3			; Display3 off
	movlw	D'180'			; Init temperature with 180 degrees Celsius
	movwf	temper			; Put it in temper file
	movlw	D'40'			; Start timer with 40 minutes
	movwf	timer			; Put it in timer file
	clrf	units			; Clear dislay's files
	clrf	tens			;
	clrf	hundreds		;
	movlw	D'255'
	movwf	buz_length		; Buzzer initial duration
	clrf	k_pressed		; Zero keys pressed state
	clrf	Key_deb			; Zero Keys debounce flag
	clrf	Key_off			; Zero Key off flag
;* DESCRIPTION: Main Program
main_loop:
	; Leds code:
	END
I have changed some of the names, re-arranged all the sub-routines and deleted some of the unnecessary code.
Fix up the names and see my comments
Let me know what happens
;* System definitions.
    LIST  P=16F677
;* Program variables and constant definitions.
tempo0        equ    0x28
tempo1        equ    0x29
aux_file    equ    0x35                        ; extra delay in H-Keeping
; Leds
#define        LED_ON                PORTA,4        ; Led on
#define        LED_OFF                PORTA,2        ; Led off
; Displays
; Keys
#define        KEY_OFF                PORTB,7        ; KEY_UP
#define        KEY_ON                PORTA,2        ; KEY_DWN
; Piezo
#define        piezo                    PORTC,0        ; piezo
;* Start of program.
    ORG        0x0000
    goto    start
;* Decode value in W register to display segments for PORTA.
;* return with  result in W
decdisp_a:
                        ;    |-|-|B|E|-|A|-|-|
decdisp_b:
;* Program Initialization
start
    clrf    ANSELH            ;    "    "    "
    clrf    tens            ;
    clrf    hundreds        ;
    movlw    D'255'
    goto    main_loop
;* Sub-routines in Alphabetical Order
        ; binary_to_bcd - 8-bits
        ; INPUT:        temper   - 8-bit binary number
        ; return:      hundreds - the hundreds digit of the BCD conversion
        ;                tens     - the tens digits of the BCD conversion
        ;                units    - the ones digits of the BCD conversion
bin2bcd:
    clrf    units            ;
    clrf    tens            ;
    movf    aux,F            ;
    retlw    00                ; Yes - Return
                            ; No
    movf    units,W            ;
    xorlw    0X0A            ;
    goto    $+3                ; No
                            ; yes
    movf    tens,W            ;
    xorlw    0X0A            ;
    goto    $+3                ; No
                            ; Yes
    retlw    00                ; Yes
H_keeping
    ; Leds:
    ;   7       6       5       4       3       2       1       0
    goto    $+3
    goto    $+2
    goto    contled            ; No
setledoff:
contled:
    goto    $+3
    bsf        LED_UP            ; No
    goto    $+2
    bcf        LED_UP            ; Yes
    goto    $+3
    bsf        LED_DWN            ; No
    goto    $+2
    bcf        LED_DWN            ; Yes
    goto    $+3
    bsf        LED_LIGHT        ; No
    goto    $+2
    bcf        LED_LIGHT        ; Yes
    goto    $+3
    goto    $+2
    goto    $+3
    bsf        LED_timer        ; No
    goto    $+2
    bcf        LED_timer        ; Yes
    goto    $+3
    bsf        LED_TEMP        ; No
    goto    $+2
    bcf        LED_TEMP        ; YES
endleds:
    ;   7       6       5       4       3       2       1       0
    bcf        STATUS,RP0        ; RP0 = 1 -> Bank 0
    bsf        STATUS,RP1        ; RP1 = 0 -> "   "2
    bcf        STATUS,RP1        ; RP2 = 2 -> "   "0
    incf    temper,F        ; Yes
    goto    $+3                ; No
    goto    $+2                ; Exit
    btfsc    KEY_timer        ;
    goto    $+3                ;
    bsf        k_pressed,5        ;
    goto    $+2                ;
    bcf        k_pressed,5        ;
    btfsc    KEY_ONOFF        ;
    goto    $+3                ;
    bsf        k_pressed,4        ;
    goto    $+2                ;
    bcf        k_pressed,4        ;
    btfsc    KEY_LIGHT        ;
    goto    $+3                ;
    bsf        k_pressed,3        ;
    goto    $+2                ;
    bcf        k_pressed,3        ;
    btfsc    KEY_TOASTER        ;
    goto    $+3                ;
    bsf        k_pressed,2        ;
    goto    $+2                ;
    bcf        k_pressed,2        ;
    btfsc    KEY_TEMP        ;
    goto    $+3                ;
    bsf        k_pressed,1        ;
    goto    $+2                ;
    bcf        k_pressed,1        ;
    btfsc    KEY_DWN            ;
    goto    $+3                ;
    bsf        k_pressed,0        ;
    goto    $+2                ;
    bcf        k_pressed,0        ;
    ;bsf        STATUS,RP0        ; RP0 = 1 -> Goto Bank 1 (RP1 already = 0)
   ; bcf        WPUA,7
    ;bcf        WPUB,7   ;the weak pull ups only work when INPUT
    bsf        STATUS,RP0        ;  0 -> 1
    bcf        OPTION_REG,7    ; Set RABPU flag  set or CLEAR?
    movlw    B'00001000'        ;
    movlw    B'00000000'        ;
    bcf        STATUS,RP0        ;1 ->  Bank 0
    retlw    00
;* Main
main_loop
    call    decdisp_a        ; turn on/off segments A,B,E
    call    decdisp_b        ; turn on/off segments C,D,F,G
    movwf    PORTB            ; put it in PORTB
    ; Leds code:
    bsf        LEDS_ON            ; Flag to turn leds on
    bcf        LED_CMN            ; clear bit 2 on PORTC to turn on LEDs
    end
Exactly the same results.
I will be back to you later because it's 01:00 AM and I have to go, at 07:00 AM to a job interview.
When I return, I will see if I can discover something.
I have added the key detect sub-routines:
bin2bcd:
    clrf    units            ;
    clrf    tens            ;
    movf    aux,F            ;
                            ; No
    movf    units,W            ;
    xorlw    0X0A            ;
    goto    $+3                ; No
                            ; yes
    movf    tens,W            ;
    xorlw    0X0A            ;
    goto    $+3                ; No
                            ; Yes
    retlw    00                ; Yes
DelayAA
    movlw    D'255'            ; This delay increase the on-time for each segment
    movwf    aux_file        ; to improve the brightness
    decfsz    aux_file,F        ;
    goto    $-1
    retlw    00
H_keeping
    ; Leds:
    ;   7       6       5       4       3       2       1       0
    goto    $+3
    goto    $+2
    goto    contled            ; No
setledoff:
contled:
    ;btfss    LEDS_ON            ; Are leds enabled? Without this, there were weird display's segments behaviour.
    ;goto    endleds            ; No, get out
   ; btfsc    leds_s,5        ; Is led up on?
   ; goto    $+3
   ; bsf        LED_UP            ; turn LED_UP OFF
   ; goto    $+2
   ; bcf        LED_UP            ; turn LED_UP ON
   ; btfsc    leds_s,4        ; Is led down on?
   ; goto    $+3
   ; bsf        LED_DWN            ; turn LED_DWN OFF
   ; goto    $+2
   ; bcf        LED_DWN            ; turn LED_DWN ON
   ; btfsc    leds_s,3        ; Is led light on?
   ; goto    $+3
   ; bsf        LED_LIGHT        ; No
   ; goto    $+2
   ; bcf        LED_LIGHT        ; Yes
   ; btfsc    leds_s,2        ; Is led toast on?
   ; goto    $+3
   ; bsf        LED_TOASTER        ; No
   ; goto    $+2
   ; bcf        LED_TOASTER        ; Yes
   ; btfsc    leds_s,1        ; Is led time on?
   ; goto    $+3
   ; bsf        LED_timer        ; No
   ; goto    $+2
   ; bcf        LED_timer        ; Yes
   ; btfsc    leds_s,0        ; Is led temp on?
   ; goto    $+3
  ;  bsf        LED_TEMP        ; No
  ;  goto    $+2
   ; bcf        LED_TEMP        ; YES
endleds:
    bcf        LEDS_ON            ; turn on the leds anode (transistor Q6)
    ;   7       6       5       4       3       2       1       0
    ;Hasn't all the following been done in Set_UP?????????????
   ; bsf        STATUS,RP0        ;0 to Bank 1
   ; bcf        OPTION_REG,NOT_RABPU ; Activate pull-up resistors - Clear RABPU flag
   ; movlw    B'00111100'        ; 0 = output - 1 = input
   ; movwf    TRISA            ; Make RA2, RA4, RA3 and RA5 inputs (RA3 is a sensor)
   ; movlw    B'11110000'        ; 0 = output - 1 = input
   ; movwf    TRISB            ; Make RB4, RB5, RB6 and RB7 inputs
   ; movlw    B'00110100'        ; 1 = enable pull-up - 0 disable it.
   ; movwf    WPUA            ; Enable RA2, RA4 and RA5 pull-up internal resistors
   ; bsf        OPTION_REG,7    ; Set RABPU flag
   ; bcf        STATUS,RP0        ;   1 -> Bank 0
    ;bsf        STATUS,RP1        ;  0 -> "   "2
   ; movlw    B'11110000'        ; 1 = enable pull-up - 0 disable it.
   ; movwf    WPUB            ; Enable RB4, RB5, RB6 and RB7 pull-up internal resistors
    ;bcf        STATUS,RP1        ; 2 -> "   "0
    ;movlw    D'255'            ; This delay increase the on-time for each segment
    ;movwf    aux_file        ; to improve the brightness
   ; decfsz    aux_file,F        ;
   ; goto    $-1
    ;This section has a number of sub-routines to detect a key press, set a flag and turn on a LED
    ;This routine detects if a key is pressed for the second
    ;time so that a LED can be turned off. It does this by detecting the
    :key is pressed and looking to see if the "not-pressed" flag has been
    ;set to indicate the key has been released between detections.
    btfsc    KEY_UP            ; When KEY_UP pressed, input=0
    goto    $+4
    btfss    k_not_pressed,6    ;key pressed - look to see if second pressing
    goto    $+2             ;(if k_not_pressed,6 is set, key has been released between detections)
    bcf        k_pressed,6        ; clear the KEY_UP flag
    btfsc    KEY_timer        ; When KEY_timer pressed, input=0
    goto    $+4
    btfss    k_not_pressed,5    ;key pressed - look to see if second pressing
    goto    $+2             ;(if k_not_pressed,5 is set, key has been released between detections)
    bcf        k_pressed,5        ; clear the KEY_timer flag
    btfsc    KEY_ONOFF        ; When KEY_ONOFF pressed, input=0
    goto    $+4
    btfss    k_not_pressed,4    ;key pressed - look to see if second pressing
    goto    $+2             ;(if k_not_pressed,4 is set, key has been released between detections)
    bcf        k_pressed,4        ; clear the KEY_ONOFF flag
    btfsc    KEY_LIGHT        ; When KEY_LIGHT pressed, input=0
    goto    $+4
    btfss    k_not_pressed,3    ;key pressed - look to see if second pressing
    goto    $+2             ;(if k_not_pressed,3 is set, key has been released between detections)
    bcf        k_pressed,3        ; clear the KEY_LIGHT flag
    btfsc    KEY_TOASTER        ; When KEY_TOASTER pressed, input=0
    goto    $+4
    btfss    k_not_pressed,2    ;key pressed - look to see if second pressing
    goto    $+2             ;(if k_not_pressed,2 is set, key has been released between detections)
    bcf        k_pressed,2        ; clear the KEY_TOASTER flag
    btfsc    KEY_TEMP        ; When KEY_TEMP pressed, input=0
    goto    $+4
    btfss    k_not_pressed,1    ;key pressed - look to see if second pressing
    goto    $+2             ;(if k_not_pressed,1 is set, key has been released between detections)
    bcf        k_pressed,1        ; clear the KEY_TEMP flag
    btfsc    KEY_DWN            ; When KEY_DWN     pressed, input=0
    goto    $+4
    btfss    k_not_pressed,0    ;key pressed - look to see if second pressing
    goto    $+2             ;(if k_not_pressed,0 is set, key has been released between detections)
    bcf        k_pressed,0        ; clear the KEY_DWN     flag
    ;This routine detects if a key is released
    btfss    KEY_UP            ; When KEY_UP not pressed, input=1
    goto    $+2
    bsf        k_not_pressed,6        ; Yes, set flag
    btfss    KEY_timer        ;
    goto    $+2                ;
    bsf        k_not_pressed,5        ;
    btfss    KEY_ONOFF        ;
    goto    $+2                ;
    bsf        k_not_pressed,4        ;
    btfss    KEY_LIGHT        ;
    goto    $+2                ;
    bsf        k_not_pressed,3        ;
    btfss    KEY_TOASTER        ;
    goto    $+2                ;
    bsf        k_not_pressed,2        ;
    btfss    KEY_TEMP        ;When KEY_TEMP not pressed, input=1
    goto    $+2                ;
    bsf        k_not_pressed,1        ;
    btfss    KEY_DWN            ;When KEY_DWN not pressed, input=1
    goto    $+2
    bsf        k_not_pressed,0
    ;This routine just detects if a key is pressed.
    ;If a key is pressed, it will set the corresponding flag
    ;Another routine will detect that the key has been released.
    ;and other routine will deal with doing something will the "key-pressed" flag.
    ;and another routine will deal with turning off the "key-pressed" flag.
    ;clear the flags file in start_up
    goto    $+3
    bcf        k_not_pressed,6
    btfsc    KEY_timer        ;
    goto    $+3                ;
    bsf        k_pressed,5        ;
    bcf        k_not_pressed,5
    btfsc    KEY_ONOFF        ;
    goto    $+3                ;
    bsf        k_pressed,4        ;
    bcf        k_not_pressed,4
    btfsc    KEY_LIGHT        ;
    goto    $+3                ;
    bsf        k_pressed,3        ;
    bcf        k_not_pressed,3
    btfsc    KEY_TOASTER        ;
    goto    $+3                ;
    bsf        k_pressed,2        ;
    bcf        k_not_pressed,2
    btfsc    KEY_TEMP        ;When KEY_TEMP pressed, input=0
    goto    $+3                ;
    bsf        k_pressed,1        ;
    bcf        k_not_pressed,1
    btfsc    KEY_DWN            ;When KEY_DWN pressed, input=0
    goto    $+3
    bsf        k_pressed,0
    bcf        k_not_pressed,0
    movlw    B'00001000'        ;
    clrf    TRISB            ; Make all PORTB output.
    retlw    00
;* Main
main
    call    DelayAA            ; delay
    ; Leds code:
    bsf        LEDS_ON            ; Flag to turn leds on?????????????????
    call    H_keeping        ; detect keys and show LEDs
    goto    main            ; Back to main
    end
When the pins are configured again as outputs, the pull-ups registers are cleared (page 60 of 16F677):
"Each of the PORTA pins, except RA3, has an
individually configurable internal weak pull-up. Control
bits WPUAx enable or disable each pull-up. Refer to
Register 4-4. Each weak pull-up is automatically turned
off when the port pin is configured as an output."
Implemented the code you posted.
	LIST  P=16F677
tempo0		equ	0x28
tempo1		equ	0x29
k_not_pressed equ	0x33					; Key off flag
; Leds
; Displays
; Keys
; Buzzer
	ORG		0x0000
	goto	start
decdisp_a:
						;	|-|-|B|E|-|A|-|-|
decdisp_b:
start:
	clrf	ANSELH			;	"	"	"
	clrf	tens			;
	clrf	hundreds		;
	movlw	D'255'
	clrf	k_not_pressed	; Zero Key off flag
    goto    main_loop
bin2bcd:
	clrf	units			;
	clrf	tens			;
	movf	aux,F			;
							; No
	movf	units,W			;
	xorlw	0X0A			;
	goto	$+3				; No
							; yes
	movf	tens,W			;
	xorlw	0X0A			;
	goto	$+3				; No
							; Yes
	return					; Yes
DelayAA
	decfsz	aux_file,F		;
	goto	$-1
	retlw	00
H_keeping:
    ; Leds:
    ;   7       6       5       4       3       2       1       0
    goto	contled			; No, it's not enabled
    goto	$+3
    goto	$+2
    goto	contled			; No
setledoff:
contled:
    goto	$+3
    bsf		LED_UP			; No
    goto	$+2
    bcf		LED_UP			; Yes
    goto	$+3
    bsf		LED_DWN			; No
    goto	$+2
    bcf		LED_DWN			; Yes
    goto	$+3
    bsf		LED_LIGHT		; No
    goto	$+2
    bcf		LED_LIGHT		; Yes
    goto	$+3
    goto	$+2
    goto	$+3
    bsf		LED_timer		; No
    goto	$+2
    bcf		LED_timer		; Yes
    goto    $+3
    bsf		LED_TEMP		; No
    goto	$+2
    bcf		LED_TEMP		; YES
endleds:
    ;   7       6       5       4       3       2       1       0
	;key is pressed and looking to see if the "not-pressed" flag has been
	goto	$+4
	btfss	k_not_pressed,6	; key pressed - look to see if second pressing
	goto	$+2				; (if k_not_pressed,6 is set, key has been released between detections)
	goto	$+4
	btfss	k_not_pressed,5	; key pressed - look to see if second pressing
	goto	$+2				; (if k_not_pressed,5 is set, key has been released between detections)
	goto	$+4
	btfss	k_not_pressed,4	; key pressed - look to see if second pressing
	goto	$+2				; (if k_not_pressed,4 is set, key has been released between detections)
	goto	$+4
	btfss	k_not_pressed,3	; key pressed - look to see if second pressing
	goto	$+2				; (if k_not_pressed,3 is set, key has been released between detections)
	goto	$+4
	btfss	k_not_pressed,2	; key pressed - look to see if second pressing
	goto	$+2				; (if k_not_pressed,2 is set, key has been released between detections)
	goto	$+4
	btfss	k_not_pressed,1	; key pressed - look to see if second pressing
	goto	$+2				; (if k_not_pressed,1 is set, key has been released between detections)
	goto	$+4
	btfss	k_not_pressed,0	; key pressed - look to see if second pressing
	goto	$+2				; (if k_not_pressed,0 is set, key has been released between detections)
	goto	$+2
	btfss	KEY_timer		; When KEY_timer not pressed, input=1
	goto	$+2				;
	btfss	KEY_ONOFF		; When KEY_ONOFF not pressed, input=1
	goto	$+2				;
	btfss	KEY_LIGHT		; When KEY_LIGHT not pressed, input=1
	goto	$+2				;
	btfss	KEY_TOASTER		; When KEY_TOASTER not pressed, input=1
	goto	$+2				;
	btfss	KEY_TEMP		; When KEY_TEMP not pressed, input=1
	goto	$+2				;
	btfss	KEY_DWN			; When KEY_DWN not pressed, input=1
	goto	$+2
	bsf		k_not_pressed,0
	goto	$+3
	bcf		k_not_pressed,6
	btfsc	KEY_timer		;
	goto	$+3				;
	bsf		k_pressed,5		;
	bcf		k_not_pressed,5
	btfsc	KEY_ONOFF		;
	goto	$+3				;
	bsf		k_pressed,4		;
	bcf		k_not_pressed,4
	btfsc	KEY_LIGHT		;
	goto	$+3				;
	bsf		k_pressed,3		;
	bcf		k_not_pressed,3
	btfsc	KEY_TOASTER		;
	goto	$+3				;
	bsf		k_pressed,2		;
	bcf		k_not_pressed,2
	goto	$+3				;
	bsf		k_pressed,1		;
	bcf		k_not_pressed,1
	goto	$+3
	bsf		k_pressed,0
	bcf		k_not_pressed,0
    bcf		WPUA,7
    bcf		WPUB,7
    movlw	B'00001000'		;
    movlw	B'00000000'		;
    retlw    00
main_loop:
	; Leds code:
	END
I understand your reasoning with this: Each weak pull-up is automatically turned
It is just the bad wording of the Microchip document.
The pullups are available again when the pin is required as an input, if the setting has been set in Set_Up.
You now have to create a sub-routine that detects if a flag has been set and turn on the appropriate LED.
You were doing too many things in the one sub-routine. You were turning on a flag or turning it off in the same sub-routine.
The flags are toggled and this toggles the LEDs.
Also you have not changed the names of the sub-routines as per my last detailed program. The names I suggested are more suitable: Start becomes set_up and main_loop becomes Main
Made the changes:
Put the init of pull-ups in set_up:
	bcf		STATUS,RP1		; RP1 = 0 -> Back to Bank 0
Renamed Start to set_up and main_loop to Main.
Compiled and burned.
Now, I need to test a key, to see if it works with these mods.
I have also cut out a lot of coding for bsf status, RP0 RP1 etc. see my last program. It clears up all your mess.
I had already cleaned up the House Keeping code for the bank election.
I just forgot to clean the set_up (1 or 2 lines).
Now, it's:
set_up:
	bsf		STATUS,RP1		; RP1 = 1 -> Bank 2 (I need it to switch to bank2)
	clrf	ANSELH			;	"	"	"
	bcf		STATUS,RP1		; RP1 = 0 -> Bank 1 ( need it to came back from bank2)
	bcf		STATUS,RP0		; RP0 = 0 (removed the bcf STATUS,RP1)
	bsf		STATUS,RP1		; RP1 = 1 -> "   " (Again, I need it to go to bank2)
	bcf		STATUS,RP1		; RP1 = 0 -> Back to Bank 0 (Again, I need it to came back from bank2)
Is this good?
