PIC and Neural Network?
amady
Hi all... :wink:
Can i programmed the Neural Network with PIC?
if can, suggestion PIC? :?:
I think (I have never tried so don't really know it) it's possible. However there are some important things to consider - most calculations are floating point operations, so you either need FP code, or find a way to use integer operations with enough precision.
Next, depending on what you need to do the PIC could be pretty slow (to train the net). If you just want it to use already trained net it could work.
Regarding the PIC type, probably the best bet would be the 18F series, but maybe you can do something smaller in 16F as well (with the above things in mind)
BR
I found it!
I was borrow from my library and i found it how to do the Neural networks project. The book is:
PIC Microcontroller project book from John Iovine
using assembly language ?
which PIC?..any external device? (such as memory?)
