P and N Channel H-Bridge with PWM
drwarm
Hey stumbled on this great forum after searching for this topic, but can't find an exact answer for my question (with schematic if possible!).
I have been looking at the circuit shown here:
I will be driving two motors from a typical R/C car supplied with 9.6V NiCad (I assume they'll draw about 1 amp).
But currently have the following items which differ slightly from those ones (sorry my part numbers might be different as I'm from Australia :) ) :
  • NPN = 2N3904
  • PNP = BC558 (general purpose PNP)
  • N-Channel MOSFET = MPT3055
  • P-Channel MOSFET = IRF9540N
From my reading on the theory of H-Bridges these should be fine, as the Rds(ON) is about the same for both MOSFETS (approx .1 Ω), and they're both logic level driven (I hope i read the datasheets correctly).
My question is do I need the transistors at all because I have logic level MOSFETS?
And can I drive this with two PWM signals as the MCU I'm using (from an autopilot) doesn't have plain digital I/O!! Otherwise I have 8 PWM signals (max) and I can just have them fully on and act like digital outputs, but I'm a little uncertain because I don't think I can fully turn them off (as they're meant to drive servo motors the only settings I have are: min="1000" neutral="1000" max="2000" which are in ms).
Hopefully that all made sense, as I'm quite an amateur!!!
Thanks for your time.
  • N-Channel MOSFET.PDF
  • P-Channel Mosfet.PDF
At 9.6V presumably these are motors from 'real' R/C cars, like Tamiya ones?.
They take massively more than 1A, 90A upwards ECS's are commonly used for controlling them.
Sorry I should have worded that better, the 9.6V is the supply to the whole RC (it is just a toy one bought from a toy store), that includes other electronics transmitter/receiver etc. I have driven it off a 1.5Amp micro controller that I used for another project some time ago with no issues.
drwarm (&fuzzy),
that diagram is dated 2001. There are much better single chip solutions around today to do the job. Driving P-channel MOSFETS is expensive.
You could probably salvage a H bridge IC from an old VCR load/mode select motor drive, if you wanted to experiment. They come as a monolithic solution, where the chip drives the motor directly, no transistors or MOSFETs to add.
The attached pdf is an older example IC. Full H bridge driving 4x N-channel MOSFETS. Very easy.
sPuDd..
  • HIP4081A MOSFET Driver IC.pdf
Still had a lot of trouble getting the H-Bridge going, but managed to find some L6203 DMOS H-bridge driver ICs.
Just a couple question before I try out the circuit, I'm using pg 11 of this pdf as reference (I won't use the L6506 and just connect micro straight to L6203):
https://www.otocoup.com/DocTech/Stepper_cont_driver_bip_2.8A_L6208_ApN_microstep.pdf
Do you think a 0.5Ω resistor is ok going from Sense to Ground?
Also is there any way to control it with just 2 PWMs per L6203, for instance if I have the two signals also go into an XOR that goes to enable?
Thanks for all your help!
PS I also know that this circuit doesn't have any dead time, I will try an accomplish this with code.
