joshua17ss2
I am trying to switch a triac, with a small load on it, 200 volts 1 amp, i have been told the moc 3010 is a sutible triac driver, would the moc3022 do the same thing safely
thanks
josh
thanks
josh
A very quick perusal of the data sheet https://www.fairchildsemi.com/ds/MO/MOC3011-M.pdfsays the only difference is that the 3022 part takes less current to turn on, than the 3010, and I can see no other difference, so it should work for you, but you should have a look yourself.joshua17ss2 said:I am trying to switch a triac, with a small load on it, 200 volts 1 amp, i have been told the moc 3010 is a sutible triac driver, would the moc3022 do the same thing safely
thanks
josh
