OPamp configurations for high slew rate.
Doug314
I need an opamp configuration with the following specs. slew rate 14 v/us, Voltage range 18V, current output typically 1.5A or 5A peak. There are configurations one can use to achieve these results using multiple opamps, I assume. I need guidance on what type of configuration I would need to achieve these results.
You cannot increase the intrinsic slew-rate of an op amp as given in their data sheet.
You have to buy one with sufficient slew-rate (probably at least 20 V/us if you need 14 V/us).
You can add transistors at the output to increase the slew rate, and the GBW.
Only if you know how to compensate for the extra gain/bandwidth to keep the circuit stable.
It's not that hard. Here's an LM324, with the slew and GBW boosted:
Used to be not very expensive and easily available.
TL072, just 13 V/us
