    Dismiss Notice
Mystery loop
Discussion in 'Microcontrollers' started by ibwev, Jan 30, 2017.
  1. ibwev
    ibwev Member
    Dec 5, 2010
    188
    0
    Shreveport, Louisiana
    When I power an RF Transmitter attached to an aduino, I am successfully sending text messages via an RF Receiver connected to a Raspberry Pi that has a GSM module attached to it. The RF sniffing code on the Raspberry Pi waits for a transmission from the RF Transmitter before sending a text. However, once the sniffing code receives the first signal, it doesn't stop sending text messages even after the transmitter has been powered off. If I comment out the line
    Code (text):
    sendSMS1.sms()
    the code works as expected. In other words, when I power off the transmitter and have the above line commented out, the sniffing program does not enter the loop at
    Code (text):
    while rx.ready():
    . However, when I uncomment
    Code (text):
    sendSMS1.sms()
    , run the program, and turn the transmitter on to send one text and immediately power it off , it continuously loops this section (line 369 - 382 of vw.py).
    Code (text):
     if (letter[len(letter) - 1]) == "L": #capture lastletter of list
                    print("The letter is L")
                    print(letter + "before send")
                    sendSMS1.sms()    #send the text
                    i += 1
                    l = list(letter)  #strings are immutable, convert to a list
                    del(l[len(letter) - 1]) #delete the last letter of the list
                    letter = "".join(l)  #assign the list of chars to the string letter
                    print(letter)
                    print(i)
    Somehow, when the transmitter is cycled on and off one time, the char "L" is re-appended to the string even though it is successfully removed after sending the text. I assume I have broken some sort of importing rule when I call
    Code (text):
     sendSMS1.sms()
    but I have tried numerous modifications and can't seem to figure it out. Any help solving this problem would be much appreciated.
    Text Code (sendSMS1.py)
    Code (text):
    import os
    import serial
    from time import sleep, time
    from string import replace
    from globalParVar import *
    from agsm2_064_hw_control import *
    from agsm_Serial_Lib import *
    from agsm_Basic_Lib import *
    from agsm_SMS_Lib import *
    def sms():    #when importing this module, the desired code must be in a definition
        message="Hi!\r\nThis message has been sent from the a-gsm v2.064 shield connected with my RPi board."
        destinationNumber="3185184930"#usually phone number with International prefix eg. +40 for Romania - in some networks you must use domestic numbers
        usePoweringControl = 1#change it to 0 if you do not want to control powerUP/powerDown the a-gsm board. In this case, please be sure the a-gsm board is powered UP(..see a-gsm_kickstart_v_x-yz.pdf) before run this utility
        print "Light example - just send a SMS to a destination number"
        sleep(1)
        if not os.getuid() == 0:
           print("please use root privileges! try: \"sudo python yourPythonFileName.py\"")
           exit(0)
        if destinationNumber=="":
           print("No destination number has been set for your SMS!")
           print("Edit the file and set the destinationNumber in line 35\r\n")
           exit(0)
    # set SERIAL/USB communication section start
    # bellow chose value bw [SER] Serial /dev/ttyAMA0 or [USB] /dev/ttyUSB0
    # if module USB port maps to other port as /dev/ttyUSB1, just edit the moduleName_Serial_lib.py...
        serialCommunicationVia = SERIALCON      # OVERRIDE the default value loaded from globalParVar.py. here I use via SERIAL communication
        setSerialCom(serialCommunicationVia)    # set the current communication option
        startSerialCom()                        # open serial communication bw. RPi and a-gsm shield
    # set SERIAL/USB communication section end
    # set HARDWARE CONTROL setup & POWER ON section start
        if usePoweringControl==1:
           hwControlSetup()                    # setup the RPi I/O ports
        sleep(2)#some delay...
           poweron()
        sleep(1)
    # set HARDWARE CONTROL setup & POWER ON section end
    # set MODEM STARTUP SETUP section start
        setupMODEM()
    # set MODEM STARTUP SETUP section end
    # MAIN PROGRAM section start
        print "try to send a SMS...."
    #check AT command pdf for proper 129/145 parameter/number format usage
        res = sendSMS(destinationNumber, "129", message)#domestic format numbers
    #res = sendSMS(destinationNumber, "145", message)#international format numbers
        if res==0:
            print "SMS has been sent with succes"
    # MAIN PROGRAM section end
    # stop SERIAL COMMUNICATION section start
        stopSerialCom()                             # close modem communication
    # stop SERIAL COMMUNICATION section end
    # HARDWARE CONTROL release & POWER OFF section start
           poweroff()                              #shutdown modem
           hwControlRelease()                      # free GPIO
    # HARDWARE CONTROL release & POWER OFF section end
        print("\r\n\r\nThat's all folks!\r\n")
    Sniffing Code (vw.py)
    Code (text):
    #!/usr/bin/env python
    This module provides a 313MHz/434MHz radio interface compatible
    with the Virtual Wire library used on Arduinos.
    It has been tested between a Pi, TI Launchpad, and Arduino Pro Mini.
    # 2014-08-14
    # vw.py
    import time
    import pigpio
    import sendSMS1
    MAX_MESSAGE_BYTES=77
    MIN_BPS=50
    MAX_BPS=10000
    _HEADER=[0x2a, 0x2a, 0x2a, 0x2a, 0x2a, 0x2a, 0x38, 0x2c]
    _CTL=3
    _SYMBOL=[
       0x0d, 0x0e, 0x13, 0x15, 0x16, 0x19, 0x1a, 0x1c,
       0x23, 0x25, 0x26, 0x29, 0x2a, 0x2c, 0x32, 0x34]
    def _sym2nibble(symbol):
       for nibble in range(16):
          if symbol == _SYMBOL[nibble]:
             return nibble
       return 0
    def _crc_ccitt_update(crc, data):
       data = data ^ (crc & 0xFF);
       data = (data ^ (data << 4)) & 0xFF;
       return (
                 (((data << 8) & 0xFFFF) | (crc >> 8)) ^
                  ((data >> 4) & 0x00FF) ^ ((data << 3) & 0xFFFF)
    class tx():
       def __init__(self, pi, txgpio, bps=2000):
          Instantiate a transmitter with the Pi, the transmit gpio,
          and the bits per second (bps).  The bps defaults to 2000.
          The bps is constrained to be within MIN_BPS to MAX_BPS.
          self.pi = pi
          self.txbit = (1<<txgpio)
          if bps < MIN_BPS:
             bps = MIN_BPS
          elif bps > MAX_BPS:
             bps = MAX_BPS
          self.mics = int(1000000 / bps)
          self.wave_id = None
          pi.wave_add_new()
          pi.set_mode(txgpio, pigpio.OUTPUT)
       def _nibble(self, nibble):
          for i in range(6):
             if nibble & (1<<i):
                self.wf.append(pigpio.pulse(self.txbit, 0, self.mics))
             else:
                self.wf.append(pigpio.pulse(0, self.txbit, self.mics))
       def _byte(self, crc, byte):
          self._nibble(_SYMBOL[byte>>4])
          self._nibble(_SYMBOL[byte&0x0F])
          return _crc_ccitt_update(crc, byte)
       def put(self, data):
          Transmit a message.  If the message is more than
          MAX_MESSAGE_BYTES in size it is discarded.  If a message
          is currently being transmitted it is aborted and replaced
          with the new message.  True is returned if message
          transmission has successfully started.  False indicates
          an error.
          if len(data) > MAX_MESSAGE_BYTES:
             return False
          self.wf = []
          self.cancel()
          for i in _HEADER:
             self._nibble(i)
          crc = self._byte(0xFFFF, len(data)+_CTL)
          for i in data:
             if type(i) == type(""):
                v = ord(i)
             else:
                v = i
             crc = self._byte(crc, v)
          crc = ~crc
          self._byte(0, crc&0xFF)
          self._byte(0, crc>>8)
          self.pi.wave_add_generic(self.wf)
          self.wave_id = self.pi.wave_create()
          if self.wave_id >= 0:
             self.pi.wave_send_once(self.wave_id)
             return True
          else:
             return False
       def ready(self):
          Returns True if a new message may be transmitted.
          return not self.pi.wave_tx_busy()
       def cancel(self):
          Cancels the wireless transmitter, aborting any message
          in progress.
          if self.wave_id is not None:
             self.pi.wave_tx_stop()
             self.pi.wave_delete(self.wave_id)
             self.pi.wave_add_new()
          self.wave_id = None
    class rx():
       def __init__(self, pi, rxgpio, bps=2000):
          Instantiate a receiver with the Pi, the receive gpio, and
          self.pi = pi
          self.rxgpio = rxgpio
          self.messages = []
          self.bad_CRC = 0
          if bps < MIN_BPS:
             bps = MIN_BPS
          elif bps > MAX_BPS:
             bps = MAX_BPS
          slack = 0.20
          slack_mics = int(slack * self.mics)
          self.min_mics = self.mics - slack_mics       # Shortest legal edge.
          self.max_mics = (self.mics + slack_mics) * 4 # Longest legal edge.
          self.timeout =  8 * self.mics / 1000 # 8 bits time in ms.
          if self.timeout < 8:
             self.timeout = 8
          self.last_tick = None
          self.good = 0
          self.bits = 0
          self.token = 0
          self.in_message = False
          self.message = [0]*(MAX_MESSAGE_BYTES+_CTL)
          self.message_len = 0
          self.byte = 0
          pi.set_mode(rxgpio, pigpio.INPUT)
          self.cb = pi.callback(rxgpio, pigpio.EITHER_EDGE, self._cb)
       def _calc_crc(self):
          crc = 0xFFFF
          for i in range(self.message_length):
             crc = _crc_ccitt_update(crc, self.message[i])
          return crc
       def _insert(self, bits, level):
          for i in range(bits):
             self.token >>= 1
             if level == 0:
                self.token |= 0x800
             if self.in_message:
                self.bits += 1
                if self.bits >= 12: # Complete token.
                   byte = (
                      _sym2nibble(self.token & 0x3f) << 4 |
                      _sym2nibble(self.token >> 6))
                   if self.byte == 0:
                      self.message_length = byte
                      if byte > (MAX_MESSAGE_BYTES+_CTL):
                         self.in_message = False # Abort message.
                         return
                   self.message[self.byte] = byte
                   self.byte += 1
                   self.bits = 0
                   if self.byte >= self.message_length:
                      self.pi.set_watchdog(self.rxgpio, 0)
                      crc = self._calc_crc()
                      if crc == 0xF0B8: # Valid CRC.
                         self.messages.append(
                            self.message[1:self.message_length-2])
                      else:
                         self.bad_CRC += 1
             else:
                if self.token == 0xB38: # Start message token.
                   self.in_message = True
                   self.pi.set_watchdog(self.rxgpio, self.timeout)
                   self.bits = 0
                   self.byte = 0
       def _cb(self, gpio, level, tick):
          if self.last_tick is not None:
             if level == pigpio.TIMEOUT:
                self.pi.set_watchdog(self.rxgpio, 0) # Switch watchdog off.
                if self.in_message:
                   self._insert(4, not self.last_level)
                self.good = 0
             else:
                edge = pigpio.tickDiff(self.last_tick, tick)
                if edge < self.min_mics:
                   self.good = 0
                elif edge > self.max_mics:
                   if self.in_message:
                      self._insert(4, level)
                   self.good = 0
                else:
                   self.good += 1
                   if self.good > 8:
                      bitlen = (100 * edge) / self.mics
                      if   bitlen < 140:
                         bits = 1
                      elif bitlen < 240:
                         bits = 2
                      elif bitlen < 340:
                         bits = 3
                      else:
                         bits = 4
                      self._insert(bits, level)
          self.last_tick = tick
          self.last_level = level
       def get(self):
          Returns the next unread message, or None if none is avaiable.
          if len(self.messages):
             return self.messages.pop(0)
          else:
             return None
       def ready(self):
          Returns True if there is a message available to be read.
          return len(self.messages)
       def cancel(self):
          Cancels the wireless receiver.
          if self.cb is not None:
             self.cb.cancel()
          self.cb = None
    if __name__ == "__main__":
       import time
       import pigpio
       import vw
       RX=27
       TX=25
       BPS=900
       pi = pigpio.pi() # Connect to local Pi.
       rx = vw.rx(pi, RX, BPS) # Specify Pi, rx gpio, and baud.
       tx = vw.tx(pi, TX, BPS) # Specify Pi, tx gpio, and baud.
       msg = 0
       start = time.time()
       while (time.time()-start) < 300:
     #     msg += 1
     #     while not tx.ready():
    #         time.sleep(0.1)
    #      time.sleep(0.2)
     #     tx.put([48, 49, 65, ((msg>>6)&0x3F)+32, (msg&0x3F)+32])
    #         time.sleep(0.1)
     #     time.sleep(0.2)
    #      tx.put("Hello World #{}!".format(msg))
          i = 0
          while rx.ready():
             print("immediately after while before join")
        letter = ("".join(chr (c) for c in rx.get())) #retrieve what was sent first 2 or 3 characters are preambles
            #time.sleep(60)  this does not help. Line does not execute until previous is finished
    #when executing sendSMS1.sms() this loop completes once the text is sent
    #I unplug the battery but code does not exit while loop and it somehow restores the string to remember the L
    #the code works as expected if I comment out the sendSMS1 command
            i += 1
            print(letter)
            print(i)
        else:
            print("failed")
       rx.cancel()
       tx.cancel()
       pi.stop()
Share This Page
