    Dismiss Notice
MIX C and Assembly in AtmelStudio
Discussion in 'AVR' started by Majid soltani, May 15, 2015.
  1. Majid soltani
    Majid soltani New Member
    May 6, 2015
    22
    0
    Hi my friend...
    I declare this variable :
    const unsigned char screen_pattern[8*8] PROGMEM = {
    10,20,0,11,0,125,255,13,
    10,20,0,0,0,125,255,13,
    10,20,115,90,0,125,255,13,
    10,47,0,0,0,125,255,13,
    10,120,0,80,0,125,255,13,
    10,200,0,0,0,125,255,13,
    10,20,0,127,0,125,255,13
    now ... i want mix C and Assembly code and send screen_pattern to PORTD with assembly code .... please help me...
  2. Ian Rogers
    Ian Rogers Super Moderator Most Helpful Member
    Mar 28, 2011
    9,148
    907
    Rochdale UK
    In the documentation it will show how to use assembly within the C environment... It will be quite straight forward...
    I don't use avr studio so I'm not sure....
  3. Majid soltani
    May 6, 2015
    22
    0
    you use which compiler ? ... please you say your solution maybe i could use that.
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. Ian Rogers
    Mar 28, 2011
    9,148
    907
    Rochdale UK
    I use Pic's.... I don't think my compiler would be much use to you.. I haven't a copy of the GNU C compiler to hand...
    Are you using AVR studio???
  6. Majid soltani
    May 6, 2015
    22
    0
    OK thank you.... Yes , I use atmelStudio 6
    now i solved my problem
    first i set an assembly name to screen_pattern[] :
    const unsigned char screen_Pattern[8*8] asm("sc_p") PROGMEM = {
    67,20,0,11,0,125,255,13,
    then use this codes :
    asm ("PUSH R16 ");
    asm ("PUSH R30 ");
    asm ("PUSH R31 ");
    // Z Register is ( R31:R30)
    asm ("LDI r30,lo8(sc_p)"); // R30 = LOW(sc_P)
    asm ("LDI r31,hi8(sc_p)"); // R31 = HIGH(sc_P)
    asm ("LPM R16 , Z "); // LPM (Load program memory) R16 = [Z] Z = first cell of screen_Pattern[]
    asm ("OUT 0x12 , R16 "); // 0x12 is address of PORTD ; PORTD=R16
    asm ("POP R31 ");
    asm ("POP R30 ");
    asm ("POP R16 ");
  7. Ian Rogers
    Mar 28, 2011
    9,148
    907
    Rochdale UK
    Why are you wanting to use C... If you are going to program in ASM just use an assembler??
  8. Majid soltani
    May 6, 2015
    22
    0
    Because ,I in a part of program have time limits and in other parts of the program do not need to spend own time writing code in assembly language.
  9. Ian Rogers
    Mar 28, 2011
    9,148
    907
    Rochdale UK
    Okay... Some of my functions are just ASM wrappers as well.... When the fastest code possible is needed..
    • Like Like x 1
Share This Page
