I'm a newbie in electronics, so before delving into the high amp side of electronics, I found it better to get some advice first.
I need to measure current consumption of two 14V DC motors in parallel under several scenarios (no load, full load, max speed, etc). The motors are of the type found in R/C monster trucks (traxxas e-maxx).
My DMM only goes up to 10 AMP, and on the traxxas forums, I've heard that these motors may go as high as 20AMP. I don't want to burn my DMM (although I believe there is a fuse in there to protect it against overcurrent).
In first place, I will install a 10AMP fuse (could only find a 250V one, is there a problem with that?) between my multimeter and the motor, but it is not going to be enough, as it will allow to measure a few situations only.
Is there any other way to measure high currents?
Considering that I'm a newbie (but I have enough skills to program a PIC, and I even know how to distinguish a resistor from a capacitor :wink: ), how easy is to build a logger with a PIC that will store peak amperes up to 30AMP over time? Is there an IC that does that?
Cheers
Padu
Cheers
Padu
