    Dismiss Notice
Looking for LCD Screen Circuit!
Discussion in 'Homework Help' started by DGS3, Apr 21, 2009.
  1. DGS3
    DGS3 New Member
    Apr 21, 2009
    2
    0
    Hi! So, me and my professor are trying to get an LCD screen he had lying around to interface with Arduino, and I can't seem to find a circuit for it anywhere. I was hoping you guys could help. The only information we have about the circuit is the label it came with, which says: LK 204-25-WB-C74. After looking that up, I found: LK204-25-WB Serial LCD Module - HVW Technologies , so I'm assuming thats the LCD screen I am working with. So, does anybody know a circuit which can interface correctly with Arduino? Thanks in advance!!
  2. UTMonkey
    UTMonkey New Member
    Oct 16, 2007
    450
    3
    Chesterfield, Derbyshire - UK
    If i'm reading this correctly, this LCD is capable of responding to RS232, I2C and a load of other stuff.
    A quick search on the internet reveals the following datasheet.
    http://www.matrixorbital.ca/manuals/LK_series/LK204-25/LK204-25.pdf
    Not knowing your level of experience with talking to remote devices I think learning to talk to the LCD via RS232 and looking for rs232 circuits would be a good starting point.
    Mark
  3. dknguyen
    dknguyen Well-Known Member
    May 6, 2006
    6,668
    64
    THat LCD module uses I2C, so you just connect the two I2C lines between the Arduino and the LCD together (don't forget the pull-up resistors required by the I2C protocal).
    It also seems to have RS-232 in which case you just connect the UART lines on the Arduino with the RS-232 lines on the LCD module (RS-232 is really UART that has a higher voltage level for noise immunity. But the LCD module probably doesn't have this higher voltage so you shouldn't need a RS232 driver IC circuit and can probably just connect them directly. You should check first though.
Share This Page
