LM35 Testing
Have you read the datasheet.?
E
  • LM35.pdf
Try this, post what you measure.
You just set it up as shown in that link. Pos and Neg to any voltage 4.5 to 9v DC and the middle leg to your Volt meter red lead on the 2v DC range and the black lead to the voltage negative.
Have just done that on my LM35 and the meter reads 0.236v which = 23.6deg C. The display is stable, but if you have the bare sensor in a cool draught it may just move up and down.
If you still get 0.005v then supsect its connected wrong or damaged.
It is showing .009V
If you have connected it up as that Embedded link or Erics picture then you should be getting a sensible reading, as you are not , can only concluded the sensors duff, you need to get a new one.
( just reversing the + and - connections for a split second are enough to blow them)
There is a chance it is working fine, if you are testing it in a freezer where the temp is 0c ..:joyful:
Hello,
I have changed the LM35 please tell how to convert it to *C
the ADC is working fine at 5V reference. left justified
lm35 is giving 10mV/*C
so, there is 10 bit ADC 2^10=1023bits
5/1023= 4.8mV
so, how to convert in *C
#include <htc.h>
__CONFIG( BOREN_OFF & PWRTE_ON & WDTE_OFF & FOSC_HS);
#define _XTAL_FREQ 20000000
void main()
TRISB=0X00;
PORTB=0X00;
TRISA = 0xff ;
ADCON1=0b00000000;
ADCON0=0b10000001;//000 = channel 0, (RA0/AN0)
ADIF=0;
ADIE=1;
PEIE=1;
while(1){
__delay_us(10);
GO_DONE=1;
__delay_us(10);
PORTB=ADRESH;
PORTB=0X00;
__delay_ms(200);
PORTB=0Xff;
__delay_ms(200);
One option is to amplify the LM35 output, to give 5v as an input to the PIC.
The working range is +2C thru 150C.
I usually scale the amp to give 4.88v out at 100C, this gives a ADC count of 1000 for 100C, so a +/-0.1C resolution.
The maths are easier for this scaling.
I AM USING 5v REFERENCE.
So!!
degrees C = (ADCin * 5v / 1024) * 100 .... As you won't be using floating point!!
degrees C = (ADCin * 500 / 1024) will give you what you want!
How to get this equation need to understand.
C:
#include <htc.h>
__CONFIG(LVP_OFF & BOREN_OFF & PWRTE_ON & WDTE_OFF & FOSC_HS);
unsigned char digits[] = {  0b00010000,0b01111101,0b00100010,0b00101000,0b01001101,0b10001000,
0b10000000, 0b00111101,0X00,0b00001000};
void main(){
TRISD=0X00;
TRISB=0X00;
PORTB=0X00;
TRISA = 0xff ;
ADCON1=0b00000000;
ADIF=0;
    ADIE=1;
    PEIE=1;
while(1){
    __delay_us(10);
GO_DONE=1;
    __delay_us(10);
unsigned char x=0;
x=ADRESH;
PORTD = 8;
x=x%10;
PORTB=digits[x];
__delay_ms(5);
PORTB=0X00;
x=ADRESH;
PORTD = 4;
x=(x/10)%10;
PORTB=digits[x];
__delay_ms(5);
PORTB=0X00;
x=ADRESH;
PORTD = 2;
x=x/100;
PORTB=digits[x];
__delay_ms(5);
PORTB=0X00;
x=ADRESL;
x=x%10;
PORTD = 1;
PORTB=digits[ADRESL];    // just for test on display working or not
__delay_ms(5);
PORTB=0X00;
Left justification??? It is easier in right justification..
11111111 11xxxxxx.. all this needs shifting 6 bits.. This is mainly for 8 bit compatibility..
xxxxxx11 11111111.. Here you can just read into a 16 bit number...
Justification is usually in ADCON1, bit 7..
C:
unsigned int result;
result = (( unsigned int) ADRESH << 2) + (ADRESL >>6); // Left!
result = (unsigned int) ADRESH << 8  + ADRESL;  //Right!
