    Dismiss Notice
Light sensor circuit..... sensitivity adjustment using resistors
Discussion in 'Electronic Projects Design/Ideas/Reviews' started by hoghunter, Aug 22, 2017.
  1. hoghunter
    hoghunter Member
    Jun 29, 2017
    195
    2
    Texas
    I have designed this simple dark sensor circuit that will turn on some LEDs at nightfall. After testing, it seems to be too sensitive, meaning it takes a fair amount of light to turn the circuit OFF. This would allow the lights to illuminate well before sunset and to keep working further into the morning. Even sitting on my kitchen table with a light on above, it does does not turn the led off. I have to add a brighter light. And then, just a shadow from my hand will turn it on.
    My question is, how can I adjust the sensitivity to require much less light to turn the circuit off? I'm assuming an adjustment to my resistor combination would do it, but not sure..... thanks.
    P.S. the system is 12v DC
  2. ronsimpson
    ronsimpson Well-Known Member Most Helpful Member
    Apr 17, 2007
    7,252
    961
    Loveland, CO USA
    The LM358 will work then the inputs are in between "GND" and "POS"-1.5V. (will not work if too close to "POS")
    You could replace R4 & R5 with a POT. Then you can set the voltage to a different level. (with in limits see above)
    OR
    I don't know which LDR you are using. Try changing R3 to 100k or 1k. I don't know which.
    R4&R5 sets a voltage to 1/2POS.
    R3&LDR sets a voltage.
    The LM358 compares these two voltages.
    So you need to change something in this balancing act.
    • Like Like x 1
  3. hoghunter
    hoghunter Member
    Jun 29, 2017
    195
    2
    Texas
    Thanks Ron,
    I'll test some different R values and see what works best. ;)
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. hoghunter
    hoghunter Member
    Jun 29, 2017
    195
    2
    Texas
    I think 47k works well for now. I appreciate the help.
  6. ronsimpson
    Apr 17, 2007
    7,252
    961
    Loveland, CO USA
    Hit the "like" button. I do not know why but I am trying to hit 1000. thanks
    • Like Like x 3
  7. AnalogKid
    AnalogKid Well-Known Member
    Sep 22, 2011
    1,101
    160
    Ohio - GMT-5
    Interesting way to draw a schematic. Are you in Australia?
    ak
    • Funny Funny x 2
  8. hoghunter
    hoghunter Member
    Jun 29, 2017
    195
    2
    Texas
    Haha.... Texas actually.. I'm new at all of this. I guess the pos+ would usually be on top?? :confused:
  9. hoghunter
    hoghunter Member
    Jun 29, 2017
    195
    2
    Texas
    Now I'm depressed...... nobody 'likes' me :(
    • Like Like x 2
  10. Inquisitive
    Inquisitive Super Moderator
    Aug 31, 2011
    924
    86
    Georgia, USA
    Thought I'd add my 1 click(s) worth.
    • Thanks Thanks x 1
  11. Reloadron
    Reloadron Well-Known Member Most Helpful Member
    Dec 23, 2009
    6,777
    281
    Cleveland, Ohio USA
    I like the name. :) Anyone in Texas going by Hog Hunter can't be all that disliked. :)
    I also gave Ron Simpson a "like" because I like his name (and his post was good).
    Ron
  12. hoghunter
    hoghunter Member
    Jun 29, 2017
    195
    2
    Texas
    Thanks guys, I'm a happy camper now!! :happy:
    Reloadron, I'm in Texas now, but was born in Cleveland.... Euclid area ;)
  13. Reloadron
    Dec 23, 2009
    6,777
    281
    Cleveland, Ohio USA
    I was NYC born and raised and wish like hell I was in Texas. :)
    Ron
  14. AnalogKid
    Sep 22, 2011
    1,101
    160
    Ohio - GMT-5
    Born a Buckeye, still a Buckeye.
    ak
  15. hoghunter
    hoghunter Member
    Jun 29, 2017
    195
    2
    Texas
    I do like the Buckeye state, but nothing beats Texas ;) Been here since '72
  16. hoghunter
    hoghunter Member
    Jun 29, 2017
    195
    2
    Texas
    I do have another electronics question for you guys..... the product I'm putting together requires a 5v step down regulator to power the digispark controller. I am currently using modules to step down the voltage. Can you recommend a simple circuit that I could add to my pcb that would step down 12v to 5v & 24v to 5v?
  17. ronsimpson
    Apr 17, 2007
    7,252
    961
    Loveland, CO USA
    How much current?
    Is heat a problem? (linear regulator like a LM7805 can get hot)
  18. AnalogKid
    Sep 22, 2011
    1,101
    160
    Ohio - GMT-5
    Little buck regulator modules on ebay are disgustingly cheap, and turning them into a "component" to install on a larger pc board is not difficult. You would have to be building a lot of assemblies to make your own design cost effective.
    ak
  19. hoghunter
    hoghunter Member
    Jun 29, 2017
    195
    2
    Texas
    Great points. I think I'll stick with the small boards I'm using now. I'll be able to plug them onto the new main board.
    thanks y'all
Share This Page
