Oznog said:The int-on-port-change is potentially confusing. Which pin was it? If it's only a short pulse on the pin, you may look at the bus, compare to what you copied off it last time, and see no change. Lost data, bummer. This is particularly likely if you've got a lot of interrupt code going on which may extend the time it takes to execute your portB change interrupt code.
