In need of assistance.
codan
Hi Everybody,
I decided to do an electronics course but i am confused with a question they ask.
They say:
A 4700 ohm resistor is rated at .5 Watts. What is the maximum safe working current.
This i am having trouble with as they do not specify a Voltage.
If i use Ohms Law i have
I = The Square Root of P/R
I = Amperes
P = Watts
R= Resistance
But how can i answer the question if i do not know the Voltage value.
If
P = V x I then the Amperage value will change due to the Voltage value.
Eg
1v X .5A = .5Watts
10v X .05A = .5Watts
Am i missing the obvious here?
Thank You
Hi Everybody,
They say:
I = Amperes
P = Watts
R= Resistance
If
Eg
1v X .5A = .5Watts
Thank You
Watts= I^2 * R
So: I^2 = W/R
I= √ (W/R)
Hi Eric,
Thanks for the reply, i guess i was thinking about it the wrong way.
I'm not sure i fully understand why voltage is not included in the calculations though.
Thank you
A Google image search for Ohm's law gives this very helpful graphic.
I keep it handy to save me the trouble of having to work out how to calculate current and voltage from power and resistance.
Actually, you could say that volts are in the equation. Since V=IR and P = I^2 R you could substitute voltage back in to the power equation getting P=VI
Consider this:
W = V²/R so V²= WR
I = V/R = (√W.R)/R
I = √W/√R = √(W/R)
Which is exactly what Eric arrived at by a different route.
Voltage was in the equation - you just replaced V with IR.
Andrew
There is only one voltage value that would drive current thru the 4700R to make it dissipate 0.5Watts.!
V^2= WR so V=√(W*R)
V^2 = 0.5 *4700
So V= 48.5v
All Ohm's law shows you the maximum continuous voltage and current .
In reality, the resistor will be able to take higher voltages and currents for a short period of time.
The peak maximum voltage rating will be specified on the datasheet.
Thanks to everyone for the replies & help it is greatly appreciated, i now have a better understanding.
Eric's last reply made it a lot easier to understand.
Thanks again
