msmukund2000
please help me on this one...
WHY IS IMPEDANCE MATCHING NECESSARY
thanks ppl..
Bye
thanks ppl..
Bye
msmukund2000 said:please help me on this one...
thanks ppl..
Bye
Spectacular Butter said:how do i know the input or output impedance of a circuit?
Nigel Goodwin said:You can measure it if you want, but again it all depends on the application, mostly you DON'T want matched impedances in electronics.
Spectacular Butter said:Nigel Goodwin said:You can measure it if you want, but again it all depends on the application, mostly you DON'T want matched impedances in electronics.
Huh why is it that you don't want matched impedance in electronics? won't it save power by using all instead of dissipating as heat?
msmukund2000 said:so if impedance matching is so selectively used, then why does an op-amp have an inbuilt impedance matching CCA? does it mean that op-amp's prospects of use are limited by this?
