    Dismiss Notice
how to tune tesla coil
Discussion in 'High Voltage' started by lokeycmos, Jun 19, 2012.
  1. lokeycmos
    lokeycmos New Member
    Oct 17, 2011
    188
    0
    my spark gap tesla coil is getting very close to done. my question is, is there a proper procedure on tuning both the spark gap and the primary tap? do i do one before the other? what are the steps involved? thank you!
  2. JimW
    JimW Member
    Dec 2, 2010
    36
    5
    I'll be interested in seeing how others respond to this. Most of my Tesla coil experience is in modern solid state versions. In my implementations, the primary coil resonance is negligible. It all comes down to the self resonance of the secondary. And this should have been determined long before this point in the build. Hopefully the self resonance of your secondary is at an acceptable frequency. I would use a signal generator and oscilloscope to figure out the secondary self resonant frequency and then match the primary to be close to that.
    Once assembled, I have always tested mine driving the primary at a reduced voltage and using an oscilloscope with a pick up coil near the secondary. Sweep the driving frequency for peak output voltage. But that is tougher to do with a spark gap, but you could try using a hundred volts and see what happens (still using a scope with a pick up coil near the secondary). Max the secondary and try various adjustments to the primary.
    -Jim
  3. lokeycmos
    Oct 17, 2011
    188
    0
    yep, i did do the signal generator and scope on my secondary and top load. it peaked at 350Khz
Share This Page
