How to define steering deadband zone?
jani12
Consider a hydraulic steering system with small electric motor atop. The maximum output torque of this motor is about 2 N.m. This output torque is input to worm gear. The output torque of the worm gear is about 20 N.m.
This steering subsystem is mounted in a prototype truck.
The requirement is that this steering subsystem must not provide steering assist while in steering deadband zone. When the handwheel is turned in deadband zone, there shall not be impact on the road wheels.
How to define steering deadband zone? For example should it be -5 deg to 5 deg or what should it be?
How would we know that?
It's your design so you need to specify how many degrees of deadband you want/expect the system to have.
Deadband is defined by +/- % max steering torque which translates into +/-deg on steering wheel where driving wheels change with some low threshold. The rationale is to spare the pump at highway speeds for long term small adjustments thus reduce the duty factor of pump operation, yet not cause noticeable tension bumps to driver.
That's not practical.
A normal worm gear cannot be "back driven" so a failure would lock up the steering.
A failure of any power boost or assist system should only cause reversion to unassisted manual steering, not cause total failure; that's just not permissible.
Measure PSI in one direction to mid-position. Subtract PSI in reverse until motion is detected = deadband PSI
% deadband = deadband PSI / total range of PSI
Cars with worm gear steering return towards straight after a corner and no load on steering wheel. This is reverse torque.
Let me re-state. Worm gear is used for torque multiplication. There is 1:10 gear ratio.
For example, if motor output torque is 2 N.m., after torque multiplication, torque at steering column or input shaft is 20 N.m.
I don't understand your reverse torque concern.
Vehicles with the main steering gear using a worm system generally use recirculating ball or similar low friction units, which can be back-driven easily with near zero loss from either side.
That is very different to trying to add an electric motor and 10:1 worm to drive the steering column itself.
(Note I did explicitly state a "conventional" worm drive - which cannot be back driven).
Also note the main steering on this is specified to be using a hydraulic power steering system.
A failure of the motor control would lock the steering solid, if such a thing was added.
An override for eg. lane keeping on such a system would usually be either additional hydraulic control, or a direct-drive torque motor added to the column, which has no significant influence or drag when unpowered.
Look here:
My first car, a 1935 MG PA had a Marles-Weller steering box with a spiral "worm wheel" (item 4) which engaged with a peg (item 11).
The steering would self centre with the castor action of the suspension, and manually moving a front wheel would turn the steering column/wheel no problem.
It took about 1.75 turns lock to lock on the steering wheel,
power assistance? not required, beautifully light steering on 4.50 x 19" tyres.
(wishing he still had the car)
Thanks for the heads up. I didn't know some worms were called self-locking.
snip
"All theoretical analyses of self-locking worm gears deal with static conditions.
In such an analysis, the load on the worm gear can’t drive the worm if the coefficient of friction between worm gear and worm is larger than the tangent of the worm’s lead angle. In other words, the friction angle must be larger than the lead angle to prevent backdriving."
That's what I'd consider to be a conventional worm drive - metal on metal, no special feature to reduce friction between the worm and wheel.
Jim's example has bearings set in the follower "pin" for friction reduction; it's not a design I'd seen before, but has the feature to allow low-loss back drive.
This is a style I'm more familiar with (my older brother is a Jaguar specialist..) - Recirculating ball, effectively a ballscrew & nut system:
Just a quick note, the bearings in the pin are not spherical balls, but hemispheres.
The flat side of the hemisphere contacts the worm, and the round side fits into a round recess in the pin.
Another thought on "dead band". Don't know much about the new electric steering, but the old hydraulic power steering the so called dead band was set by the steering valve built into the steering box. The valve only supplied power after a certain amount of torque was applied to it from the steering wheel/shaft.
The only problem I can see with it working like that is that it wouldn't allow the steering to self center after a turn.
That is actually the normal operation with hydraulic power steering.
The pressure, return and both cylinder ports are all open to each other (port overlap) when there is no torque on the column, so nothing counters the centering force from the suspension geometry or blocks the power cylinder from being moved.
Torque on the column from the steering wheel progressively closes off one or another set of ports, to direct pump flow through the actuating cylinder in the appropriate direction.
There is no true "dead band" where movement has absolutely zero effect, it's just that small movement add little bias to the flow so very small force imbalance at the power cylinder.
That is progressively increased as more torque is applied and the port areas allowing free flow get smaller, until with sufficient steering torque all pump flow has to go in one direction through the power cylinder.
Example of one type of column valve; different types have different numbers of port sets, but are generally similar
Another example in this page:
