Brownout,
I was hoping you would enumerate the failures of the diagram in the attachment I sent.
Agreement is what is important.
As long as we are clear about a couple of things. Vbi = Vn + Vp and Vbi is cancelled across the diode, not the junction.
Agreed, as long as you realize that the cancellation is across the whole diode, and the constant Vbi across the junction does not change.
Good, that is what I want agreement on. Actually the forward bias voltage is +Va to make Vbi-Va, but I won't quibble. And "the voltage in the depleation region", which encompasses the PN junction, but not the whole diode, is another name for the junction voltage Vj, right? Then Vj = Vbi-Va, so when Va is 0, Vj = Vbi. Therefore, we have the b-e terminals at 0 volts and the internal PN junction voltage at Vbi.
Do I still understand you to think that the voltage across the whole diode to be the same as the junction voltage? The above sentence is a little confusing. The junction voltage (Vbi-Va) and voltage across the whole diode Va are two separate voltages.
Ratch
They have various weaknesses. Most are too simple to be dependable.
It's exactly what I said before. I've re-read what I wrote, evidently you haven't.
My statement is correct, as explained below.
A PN junction is more than just a depletion region. vbi is cancelled by vn and vp during equalibrium and during forward bias. Nothing you've written has shown otherwise. Va changes and total depletion voltage changes, but vbi is still cancled, as it is nothing more then the intrinsic voltage, and does not change.
In other words, the voltage in the depleation region is reduced to vbi - va, under the condition of forced applied voltage. vbi is a constant, however, and does not change. Hence, the voltage across the diode is, from the perspective of the steady state voltage, equal to -va.
The reason is because the change of barrier potential is identically equal to the voltage across the whole diode, the junction voltage ( as defined by Sedra and Smith ). This is bacause of the resaons given above.
Ratch
