How do I put a comma in a decimal number and place it on the screen of the LCD?
Winch
I read an AD input and would like to insert a comma in the result. (see the code)
Adcin 0, an0  'read AN0 and write value to AN0
    Lcdcmdout LcdLine1Pos(12)
    Lcdout #an0
    Lcdcmdout LcdLine1Pos(1)
    Lcdout "Volt"
        pc1 = an0 * 6 / 10
            Lcdcmdout LcdLine1Pos(6)
    Lcdout #pc1
        WaitMs 250
    Lcdcmdout LcdClear
Goto main
End
I am not entirely sure what you want but
Lcdout ","
will place a comma in the next location... If you want to place a comma in the decimal number you will need to split it up!!!
Show me an example output of what you need.... ie
Volt 1,024
If this is what you need I would use a function to build a string...
Yes, I need your example of the "volt 1,024"
Basicly I reed the AD converter and set the code to the right voltage.
In this proces I need that comma in the end result!
I was hoping that there was a special code for this kind of problem.
What is your idea of the string?
I wrote a floating point LCD out function ( before Vladimir included singles )
number(5) as byte
number(0) = value / 1000 MOD 10 + 48
number(1) = ","
number(2) = value /100 MOD 10 + 48
number(3) = value /10 MOD 10 + 48
number(4) = value MOD 10 + 48
number(5) = 0
for x = 0 to 5
   Lcdout #number(x)
next x
Something like this
Dear Ian,
I try your solution but it doesn't work?
I see what you are doing but it works like a counter!
At the end I write the next code (see below)
main:  'endless loop
    Lcdcmdout LcdLine2Pos(12)  'write from position 12
    Lcdout #an0  'just to see on the screen what the digital number is!
    Lcdcmdout LcdLine1Pos(1)  'write from first position
    Lcdout "Volt"  'write the word "volt" on the screen!
        pc0 = an0 * 594 / 100000 Mod 10
    Lcdout #pc0
        pc1 = an0 * 594 / 10000 Mod 10
    Lcdcmdout LcdLine1Pos(7)
    Lcdout #pc1
    Lcdcmdout LcdLine1Pos(8)
    Lcdout ","
        pc2 = an0 * 594 / 1000 Mod 10
    Lcdcmdout LcdLine1Pos(9)
    Lcdout #pc2
Goto main
End
