Kryten
Hello I get som errors when I try to compile with Hi-Tech c compiler.
I use the lcd.c and get errors when compiling..
Errors:
The lcd.c file as is:
It seems that the compiler thinks that all functions are done twice or something..
My main file:
I really apreciate help..
And I know its here I can get it
Im going to have at least one DS18B20P connected later on. I need to get this working first and work my way up to the final point....
Will post about the totalt project as I get it going
Errors:
Error [237] C:\Users\Karl Kristian\Documents\C prosjekter\LCD_test2\include\lcd.c; 38. function "_lcd_write" redefined
Error [237] C:\Users\Karl Kristian\Documents\C prosjekter\LCD_test2\include\lcd.c; 51. function "_lcd_clear" redefined
Error [237] C:\Users\Karl Kristian\Documents\C prosjekter\LCD_test2\include\lcd.c; 60. function "_lcd_puts" redefined
Error [237] C:\Users\Karl Kristian\Documents\C prosjekter\LCD_test2\include\lcd.c; 69. function "_lcd_putch" redefined
Error [237] C:\Users\Karl Kristian\Documents\C prosjekter\LCD_test2\include\lcd.c; 80. function "_lcd_goto" redefined
Error [237] C:\Users\Karl Kristian\Documents\C prosjekter\LCD_test2\include\lcd.c; 87. function "_lcd_init" redefined
* LCD interface example
* Uses routines from delay.c
* This code will interface to a standard LCD controller
* like the Hitachi HD44780. It uses it in 4 bit mode, with
* the hardware connected as follows (the standard 14 pin
* LCD connector is used):
* PORTD bits 0-3 are connected to the LCD data bits 4-7 (high nibble)
* PORTA bit 3 is connected to the LCD RS input (register select)
* PORTA bit 1 is connected to the LCD EN bit (enable)
* To use these routines, set up the port I/O (TRISA, TRISD) then
* call lcd_init(), then other routines as required.
#ifndef _XTAL_FREQ
// Unless specified elsewhere, 4MHz system frequency is assumed
#define _XTAL_FREQ 8000000
#endif
#include <htc.h>
#include "lcd.h"
#define LCD_RS RA4
#define LCD_RW RA2
#define LCD_EN RC5
#define LCD_DATA PORTC
#define LCD_STROBE() ((LCD_EN = 1),(LCD_EN=0))
/* write a byte to the LCD in 4 bit mode */
void lcd_write(unsigned char c)
__delay_us(40);
LCD_DATA = ( ( c >> 4 ) & 0x0F );
LCD_STROBE();
LCD_DATA = ( c & 0x0F );
LCD_STROBE();
* Clear and home the LCD
void lcd_clear(void)
LCD_RS = 0;
lcd_write(0x1);
__delay_ms(2);
/* write a string of chars to the LCD */
void lcd_puts(const char * s)
LCD_RS = 1; // write characters
while(*s)
lcd_write(*s++);
/* write one character to the LCD */
void lcd_putch(char c)
lcd_write( c );
* Go to the specified position
void lcd_goto(unsigned char pos)
LCD_RS = 0;
lcd_write(0x80+pos);
/* initialise the LCD - put into 4 bit mode */
void lcd_init()
char init_value;
ADCON1 = 0x06; // Disable analog pins on PORTA
init_value = 0x3;
TRISA=0;
TRISC=0;
LCD_RS = 0;
LCD_EN = 0;
LCD_RW = 0;
__delay_ms(15); // wait 15mSec after power applied,
LCD_DATA = init_value;
LCD_STROBE();
__delay_ms(5);
LCD_STROBE();
__delay_us(200);
LCD_STROBE();
__delay_us(200);
LCD_DATA = 2; // Four bit mode
LCD_STROBE();
lcd_write(0x28); // Set interface length
lcd_write(0xF); // Display On, Cursor On, Cursor Blink
lcd_clear(); // Clear screen
lcd_write(0x6); // Set entry Mode
My main file:
// Temp from DS18S20 to LCD //
// PIC16F688 //
#include <pic.h>
//#include "delay.h"
#include "include\lcd.c"
__CONFIG (UNPROTECT & MCLRDIS & PWRTDIS & WDTDIS & INTOSCIO & BOREN);
// Port setup //
#define DS1820_DATAPIN RA0
// Div routines //
// Main routine //
void main (void)
TRISC = 0;
lcd_init();
lcd_goto(0); // select first line
lcd_puts("12345678");
lcd_goto(0x40); // Select second line
lcd_puts("Hello world");
for(;;);
