cyb0rg777
I have been wandering around the net looking for some things that would make our hobby easier.I have a couple of things that are maybe already out that I can't find information on.
1.USB to standard port converter chips.I want a chip that will convert USB to USART and/or SPP(parallel port).I think they should have standard drivers that allows the software to register them as either a serial or parallel port.I have found a couple chips but 48 pins is overkill for a simple standard application.
2.Conductive ink and/or glue. Life would be so much easier if you could use SMT by simply glueing the parts in place and drawing the traces by hand.I read the wikipedia article on conductive ink and it says you can draw traces on paper.Maybe you could print conductive ink and glue the pieces. I guess if you messed up you would just rip your pieces off and start over.I have found a pen from radioshack that writes conductive ink but not much info.
Where is this stuff and if we have it why are we not using it? Please add your own ideas if you want something that is not on the market or you can't find.
