Correct. At the moment pin 12 is > pin13 (i.e 'wrong way round'). Ifyou can't adjust it as required the fixed resistor which you added in series with the trimmer may need to be moved to the 'other end' of the trimmer.Pin 13 of LM324 adjusts from 15.09-15.72V. Pin 12 is 15.77V. (With R1 jumped and battery disconnected) IIRC, we need pin 13 – pin 12 = 50mv.
Don't know for sure. Probably. You can check by connecting your DMM (on the appropriate Ohms range, circuit power off) between the suspected wiper leg (the offset one) and each of the other legs in turn. If both readings are ~1k (with the trimmer set to its mid-point) then the offset leg is the wiper. That should connect directly to pin 13 of the LM324.Am I correct to assume the offset leg is the wiper?
If that 'other' leg is not the wiper then it should go to the 1k5/33k resistor string.Of the other two legs, one is connected to pin 13 of LM324.
Yes, if you can't get the adjustment you need with the connections I've just described. You may not even need the 1k5 (it all depends on manufacturing tolerances).Remove the 1K5 that is in series with the 33K and install the 1K5 in series with the 10K. Is that right?
Ok. So something higher than 1k5 needs to replace it. Try 2k2 (I think that's in your kit).Jumping the 1k5 that is in series with the 33k pushed us in the wrong direction.
Good. If you've got 15.76V at pin 12 then ideally you need ~15.81V at pin 13.I adjusted the trimmer until the fan and lights came on. Then, with battery disconnected and R1 jumped pin 13 showed 15.83-15.89.
That would explain thingsI had the volts off by a factor of ten
I'm pleased that's sorted.The charging system works beautifully
Guess we'll never know why. I'm slowly finding my way round the new site.So far, my computer gets along MUCH better with this site since the upgrade.
Nah. Just a bit of clip art from somewhere. Seemed appropriate as the Welsh flag has a dragon (more like EricGibb's avatar....not sure if Eric has Welsh connections). Time you uploaded your 'Salty' avatar?I like your dragon, Alec. Did you draw it?
