    Dismiss Notice
Help with proper grounding of tesla coil
Discussion in 'High Voltage' started by lokeycmos, May 12, 2012.
  1. lokeycmos
    lokeycmos New Member
    Oct 17, 2011
    188
    0
    Right now im really confused about proper grounding of the different components in a tesla coil. im finding so much contradicting information on the internet.i read that RF ground should not connect to transformer Ground, the opposite of what the schematic shows. hopefully someone can shed some light on this for me. i attached a drawing to refer to. basically just wondering which points get connected to eachother and whether they go to earth ground or mains ground.
    A=mains ground
    B= Ground on the EMI noise filter
    C=chassi of HV transformer also common to center tap of output
    D=transformer ground on terry filter
    E=RF ground on terry filter
    F=Ground point for the strike ring
    G= earth ground for the bottom of the secondary
  2. DerStrom8
    DerStrom8 Super Moderator Most Helpful Member
    Aug 9, 2010
    5,484
    503
    Vermont (GMT-5:00)
    Hi Lokey--
    The bottom end of the secondary should not be connected to any other part of the circuit. Period. It should be connected to a long metal stake pounded into the earth. All other grounds should be okay to connect to the NST ground. I believe that's how it's supposed to be connected, but perhaps someone can verify that for me.
    So you getting close to having it running? ;)
    Regards,
    Der Strom
  3. lokeycmos
    Oct 17, 2011
    188
    0
    im getting there slowly but surely. i have the primary, secondary, strike ring, and terry filter setup. at the moment im working on the adjustable spark gap and the capacitor. i totally cant afford to buy caps so im experimenting with sheets of glass and tinfoil. my bucket cap shattered while testing it.
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. lokeycmos
    Oct 17, 2011
    188
    0
    this schematic adds to the confusion. it shows the RF ground going to the NST center tap. which i was told is spossed to goto mains ground.
  6. DerStrom8
    Aug 9, 2010
    5,484
    503
    Vermont (GMT-5:00)
    Sounds like it's coming right along! Do you have a cap meter, or a DMM that can measure capacitance? It will help you a lot--I bought one just for that reason: To measure the capacitance of my homemade capacitors for my tesla coil. If you don't have one, I highly recommend you get one. Last I knew, Kmart was selling good craftsman multimeters with a capacitance function for $25. I bought mine there and it's lasted me 5 years already. I highly recommend them. Also, with crafstman, there's a lifetime warranty on it--if it breaks, you can get it replaced at no cost :)
    The NST center tap is often connected to mains ground. I don't think it would be much of a problem in this case. To make it even more confusing for you, here's a (complex) tesla coil schematic showing the connections of each part of the tesla coil circuit. The most important part I think you'll find interesting is the first stage:
    you can see that mains ground, NST center tap/ground, and RF ground are all connected to the same line (connection between NST and mains is shown by a symbol). Hopefully this clears it up a little.
    Good luck!
    Der Strom
  7. lokeycmos
    Oct 17, 2011
    188
    0
    yes i do have a cap meter. i bought a cheapy 20 dollar LCR meter off of ebay.
Share This Page
