    Dismiss Notice
Help regarding 16F688 LCD Voltmeter...
Discussion in 'Oshonsoft' started by manoj soorya, May 7, 2016.
  1. manoj soorya
    manoj soorya Member
    Aug 23, 2014
    238
    4
    India
    HI all
    I just make the voltmeter. But how it convert to measure 0 to 2000 mV (0-2 V)? .
    and this is the code the author supplied..
    Code (text):
      Digital Voltmeter based on PIC16F688
      Rajendra Bhatt, Oct 12, 2010
    // LCD module connections
    sbit LCD_RS at RC4_bit;
    sbit LCD_EN at RC5_bit;
    sbit LCD_D4 at RC0_bit;
    sbit LCD_D5 at RC1_bit;
    sbit LCD_D6 at RC2_bit;
    sbit LCD_D7 at RC3_bit;
    sbit LCD_RS_Direction at TRISC4_bit;
    sbit LCD_EN_Direction at TRISC5_bit;
    sbit LCD_D4_Direction at TRISC0_bit;
    sbit LCD_D5_Direction at TRISC1_bit;
    sbit LCD_D6_Direction at TRISC2_bit;
    sbit LCD_D7_Direction at TRISC3_bit;
    // End LCD module connections
    char Message1[] = "DVM Project";
    unsigned int ADC_Value, DisplayVolt;
    char *volt = "00.0";
    void main() {
      ANSEL = 0b00000100; // RA2/AN2 is analog input
      ADCON0 = 0b00001000; // Analog channel select @ AN2
      ADCON1 = 0x00;
      CMCON0 = 0x07 ; // Disbale comparators
      TRISC = 0b00000000; // PORTC All Outputs
      TRISA = 0b00001100; // PORTA All Outputs, Except RA3 and RA2
      Lcd_Init();  // Initialize LCD
      Lcd_Cmd(_LCD_CLEAR);  // CLEAR display
      Lcd_Cmd(_LCD_CURSOR_OFF);  // Cursor off
      Lcd_Out(1,1,Message1);
      Lcd_Chr(2,10,'V');
    do {
      ADC_Value = ADC_Read(2);
      DisplayVolt = ADC_Value * 2;
      volt[0] = DisplayVolt/1000 + 48;
      volt[1] = (DisplayVolt/100)%10 + 48;
      volt[3] = (DisplayVolt/10)%10 + 48;
      Lcd_Out(2,5,volt);
      delay_ms(100);
      } while(1);
    [code]
  2. manoj soorya
    manoj soorya Member
    Aug 23, 2014
    238
    4
    India
    Its work perfect....
    this is the actual link...
    http://www.electronics-lab.com/project/pic16f688-digital-voltmeter/
    and this is the calculations.....
    The accuracy depends upon the accuracy of the resistors at the input end and the stability of reference voltage, Vdd = +5V. I found Vdd is stable to +5.02 V. I measured R1 and R2, and their values are 1267 and 3890 Ohms. So this gives,
    0 – 5.02 V Analog I/P ---> 0-1023 Digital Count
    => Resolution = (5.02 - 0)/(1023-0) = 0.004907 V/Count
    Va = 1267*Vin/(1267+3890) = 0.2457*Vin
    => I/P voltage = 4.07*Va = 4.07* Digital Count * 0.004907
    = 0.01997 * Digital Count
    = 0.02*Digital Count (Approx.)
    To avoid floating point, use I/P voltage = 2*Digital Count.
    Example, suppose Vin = 7.6V. Then,
    Va = 0.2457*Vin = 1.87V
    => Digital Count = 1.87/0.004907 = 381
    => Calculated I/P Voltage = 2*381 = 0762 = 07.6V (First 3 digits of 4 digit product)
    Thanks in Advance.....
Share This Page
