[HELP] Need to compile and convert this code [mikroC]
bluesam
Dear all,
I need to compile and convert this mikroC code for PIC16F877A to get a hex file.
Since I don't have the software, would you guys help me to get that hex file for me?
This program is about interfacing lm35dz-pic16f877a-lcd16x2 by Satiesh Kumar.
note: I use 4MHz Ceramic Resonator on OSC1 and OSC2
/*Header******************************************************/
// LCD module connections
sbit LCD_RS at RB4_bit;
sbit LCD_EN at RB5_bit;
sbit LCD_D4 at RB0_bit;
sbit LCD_D5 at RB1_bit;
sbit LCD_D6 at RB2_bit;
sbit LCD_D7 at RB3_bit;
sbit LCD_RS_Direction at TRISB4_bit;
sbit LCD_EN_Direction at TRISB5_bit;
sbit LCD_D4_Direction at TRISB0_bit;
sbit LCD_D5_Direction at TRISB1_bit;
sbit LCD_D6_Direction at TRISB2_bit;
sbit LCD_D7_Direction at TRISB3_bit;
// End LCD module connections
unsigned char ch;                    //
unsigned int adc_rd;                 // Declare variables
char *text;                          //
long tlong;                          //
void main() {
    INTCON = 0;                      // All interrupts disabled
    ADCON1 = 0x82;                   // A/D voltage reference is VCC
    TRISA = 0xFF;                    // All port A pins are configured as inputs
    Delay_ms(2000);                    // Rest of pins are configured as digital
    Lcd_Init();                      // LCD display initialization
    Lcd_Cmd(_LCD_CURSOR_OFF);        // LCD command (cursor off)
    Lcd_Cmd(_LCD_CLEAR);             // LCD command (clear LCD)
    text = "ADC_Display";       // Define the first message
    Lcd_Out(1,1,text);               // Write the first message in the first line
    text = "LCD example";            // Define the second message
    Lcd_Out(2,1,text);               // Define the first message
    text = "voltage:";               // Define the third message
    while (1) {
        adc_rd = ADC_Read(2);        // A/D conversion. Pin RA2 is an input.
        Lcd_Out(2,1,text);           // Write result in the second line
        tlong = (long)adc_rd * 5000; // Convert the result in millivolts
        tlong = tlong / 1023;        // 0..1023 -> 0-5000mV
        ch = tlong / 1000;           // Extract volts (thousands of millivolts)
                                     // from result
        Lcd_Chr(2,9,48+ch);          // Write result in ASCII format
        Lcd_Chr_CP('.');
        ch = (tlong / 100) % 10;     // Extract hundreds of millivolts
        Lcd_Chr_CP(48+ch);           // Write result in ASCII format
        ch = (tlong / 10) % 10;      // Extract tens of millivolts
        ch = tlong % 10;             // Extract digits for millivolts
        Lcd_Chr_CP('V');
        Delay_ms(1);
Your help is absolutely thanked.
bluesam
@Raj: thx, i'll give a try to download it.
@all: I still need help to convert it as a comparison and a back up. (I have a decent internet connection)
Dear Raj and all too,
I got your link and gave some try.
I did get a hex file but when I burn it to PIC16f877a, it got this error message:
Fuse error 0x..
Good 0x..
Bad 0x..
a. What is it mean guys?
b. Can you help me to get that hex file that works?
Many thanks
samuel
hi guys,
after i posted the question above, i've finally found the answer
a. This probably would be because the config word is not set-up correctly for a 16F877A. I would said that the code space did program correctly as microC or your software does not try to program the config word if there is a verify error before hand
(by someone named newfound and jim)
Tools: Valid Fuses
When programming a PIC chip, the fuse settings must be set. For example, if a 20Mhz crystal is used, the fuse must be set to 'HS'. To set "Code Protection from External Reads", the fuse must be set to 'PROTECT'. An sample line of C, included before main() is shown next.
#fuses HS,PROTECT //fuse settings
A nice feature of CCS is the ability to find valid fuse settings for a particular micro. Simply select "View >> Valid Fuses" for a list.
(from CCS C review in PIC micros and C)
b. Use the fixhex2.exe which is often provided alongside MicroBrn
this is the link but the old one:**broken link removed**
hope this will be helpful
bluesam
