    Dismiss Notice
"Hello World" in C from dsPIC30F2020
Discussion in 'Microcontrollers' started by kchriste, Sep 9, 2008.
  1. kchriste
    kchriste New Member Forum Supporter
    Jul 23, 2006
    3,677
    47
    Victoria BC, Canada
    Since there seems to be very little "simple" code for the dsPIC;
    here is a "Hello World" example for the dsPIC30F2020 for any who may be interested:
    Code (text):
    /* This is a "Hello world" example for the dsPIC30F2020. It will toggle all
    *  IO pins on the chip at a rate which is visible from a LED connected to
    *  one of the IO pins. It uses the slow internal oscillator so all that is
    *  needed is a 10K pullup resistor on MCLR (pin 1 on a 28 pin DIP chip) and
    *  power connected to ALL Vdd, Vss, AVdd, and AVss pins. Don't forget to
    *  put some 0.1uF bypass capacitors across the power pins close to the PIC.
    #include <p30f2020.h>
    _FOSC(CSW_FSCM_OFF & FRC_LO_RANGE & OSC2_IO); //Oscillator Configuration
    _FOSCSEL(FRC);                                //Oscillator Selection
    _FWDT(FWDTEN_OFF);                            //Turn off WatchDog Timer
    _FGS(CODE_PROT_OFF);                          //Turn off code protect
    _FPOR( PWRT_OFF );                            //Turn off power up timer
    int main(void)
        unsigned long x;
        ADPCFG = 0xffff;    //make ADC pins all digital
        TRISA = 0;      //Make all PORTs all outputs
        TRISB = 0;
        TRISD = 0;
        TRISE = 0;
        TRISF = 0;
        while(1)
            for( x=0; x<100000; x++){;} //Delay apx 200ms
            LATA = ~LATA;           //Toggle all bits on ALL ports
            LATB = ~LATB;
            LATD = ~LATD;
            LATE = ~LATE;
            LATF = ~LATF;
        return 0;
    Edit: The compiler used was MicroChip's C30 student edition which is available for free on their site.
  2. Mike - K8LH
    Mike - K8LH Well-Known Member
    Jan 22, 2005
    3,637
    109
    Michigan, USA
    Thank you. I hope to be experimenting with a dsPIC soon.
    I think Futz may have an example on his web site.
    Regards, Mike
  3. Pommie
    Pommie Well-Known Member Most Helpful Member
    Mar 18, 2005
    10,015
    317
    Brisbane Australia
    I have a 30F2012 half wired up on a breadboard so I shall be trying this shortly - probably tomorrow.
    This will be a good start point, thank you.
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. kchriste
    Jul 23, 2006
    3,677
    47
    Victoria BC, Canada
    I did check out some of Futz's posts here, but they were for a different dsPIC and were more practical and thus more complex. The PIC programmed and worked perfectly on the first try, though I did debug the code in SIM first. On another note:
    While reading though the C30 Compiler User’s Guide I found this amusing piece of code:
    Code (text):
    void __attribute__((boot)) chuck_cookies()
    int hurl;
    int them = 55;
    char *where = "far";
    splat(where);
Share This Page
