birdman0_o
Active Member
I'm going to go ahead and assume you PM'ed those that you chose!
Otherwise I think I'm going to need to cannibalize drill motors and such to get anything with a decent size moving.
I was just trying out your wav to digital converter program, but it didnt seem to work (im running vista) it had a error while loading a .wav file
"access violation at address 0048D9ED in module BTc.exe
Read of address 032FC508"
OK, the winners are;
Birdman - please PM me your address
Gaspode - have address
Mike2545 - please PM me your address
Allvol - have address
Giftiger - please PM me your address
Wombweller - please PM me your address
Special mention;
Blueroom - ill send you - have your address
3v0 - ill send you - have your address
mohd.S.H - you DO NOT get one - thanksssssssss
So please PM me with your mailing addresses if you have not done so already. It's a few more units than i expected so I'll need to solder up some more serial leads, should be ready by tomorrow.
Also! If anyone does NOT want the standard Slave1 PIC firmware installed, please choose a different firmware from this list (and make it snappy);
TalkBotBrain.com Source Files
I suggest you consider Slave4 that will play 4 sounds controlled by 4 switches, or maybe Slave6 that will randomly choose any one of the sounds when a single switch is pressed.
Of course anyone who can program ICSP the PIC 16F628 and can understand my C source code can modify the source code to suit, or you can just control it by serial 19200 baud. Anway please let me know!
