    Dismiss Notice
Gnu c math.h pow bug
Discussion in 'Computers and Networks' started by Inquisitive, Oct 11, 2013.
  1. Inquisitive
    Inquisitive Super Moderator
    Aug 31, 2011
    947
    87
    Georgia, USA
    I'm playing with GNU C on Ubuntu 12.04 LTS on a 64bit system.
    When I compile the program using a makefile I get an error:
    "undefined reference to `pow'
    collect2: ld returned 1 exit status"
    But if compiled with the same command line that is used in the makefile but use it in a terminal window it compiles without errors and functions normally. What is going on here?
    Here is the makefile.
    Code (makefile):
    # build an executable named fig04_06 from fig04_06.c
    all: fig04_06
        gcc -g -Wall fig04_06.c -lm -o fig04_06
    clean:
        $(RM) fig04_06
    Here is the C program that is giving the math.h pow error.
    Code (GNU C):
    //    Fig. 4.6:    fig04_06.c
    //    Calculating compound interest
    #include <stdio.h>
    #include <math.h>
    //    function main begins program execution
    int main( void )
        double amount;    // amount on deposit
        double principal = 1000.0;    //    starting principal
        double rate = .05;    //    annual interest rate
        unsigned int year;    //    year counter
        //    output table column heads
        printf( "%4s%21s\n", "Year", "Amount on deposit" );
        //    calculate amount on depposit for each of ten years
        for ( year = 1; year <= 10; ++year ) {
        //    calculate new amount for specified year
        amount = principal * pow( 1.0 + rate, year );
        //    output one table row
        printf( "%4u%21.2f\n", year, amount );
        }    //    end for
        return 0;
    }    //    end function main
    Any ideas as to how to solve this?
    Thanks!
  2. misterT
    misterT Well-Known Member Most Helpful Member
    Apr 19, 2010
    2,697
    368
    Finland
    I think you should put the -lm at the end of the command. This is due to the mechanics how makefile works.
  3. Inquisitive
    Aug 31, 2011
    947
    87
    Georgia, USA
    First running "make clean"
    Editing the makefile to
    Code (makefile):
    gcc -g -Wall fig04_06.c -o fig04_06 -lm
    Produces same error
    However executing the statement gcc -g -Wall fig04_6.c -o fig04_06 -lm in a terminal window command line produces no errors and compiles as expected.
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. misterT
    Apr 19, 2010
    2,697
    368
    Finland
    Could you post the full output of the make.
  6. Inquisitive
    Aug 31, 2011
    947
    87
    Georgia, USA
    Like this?
    Code (makefile output):
    lepo@ubulap:~/DeitelC/Ch04$ make
    cc    fig04_06.c  -o fig04_06
    /tmp/ccs1glMa.o: In function `main':
    fig04_06.c:(.text+0x87): undefined reference to `pow'
    make: *** [fig04_06] Error 1
  7. misterT
    Apr 19, 2010
    2,697
    368
    Finland
    Maybe the problem is that you are trying to use Makefile as a script. It is not meant to work that way.
    This is a nice clean template for a makefile.
    Code (text):
    CC = gcc
    CFLAGS =-Wall-W
    LDFLAGS =-lm
    myprog: myprog.o more_code.o
           ${CC} ${CFLAGS} myprog.o more_code.o ${LDFLAGS}-o myprog
    myprog.o: myprog.c
           ${CC} ${CFLAGS}-c myprog.c
    more_code.o: more_code.c
           ${CC} ${CFLAGS}-c more_code.c
    clean:
           \rm myprog.o more_code.o myprog
    For you the file is something like:
    Code (text):
    CC = gcc
    CFLAGS =-Wall-W
    LDFLAGS =-lm
    fig04_06: fig04_06.o
           ${CC} ${CFLAGS} fig04_06.o ${LDFLAGS}-o fig04_06
    fig04_06.o: fig04_06.c
           ${CC} ${CFLAGS}-c fig04_06.c
    clean:
           \rm fig04_06.o fig04_06
  8. misterT
    Apr 19, 2010
    2,697
    368
    Finland
    Actually, try if this simpler version works..
    (Sorry, I'm rustier with makefiles than I thought.)
    Code (makefile):
    all: fig04_06
    fig04_06: fig04_06.c
        gcc -o fig04_06 fig04_06.c -g -Wall -I -lm
    clean:
        $(RM) fig04_06
    [/quote]
  9. Inquisitive
    Aug 31, 2011
    947
    87
    Georgia, USA
    Which produces
    makefile:5: *** missing separator.  Stop.
  10. misterT
    Apr 19, 2010
    2,697
    368
    Finland
    Yeah, the syntax is not spot on. The indentations need to be tabs.. there might be something else also.
  11. Inquisitive
    Aug 31, 2011
    947
    87
    Georgia, USA
    yes, it was a tab needed in the makefile before the gcc statement.
    make file runs now but still have this error to replace it on make
    /tmp/ccXuFfFV.o: In function `main':
    /home/lepo/DeitelC/Ch04/fig04_06.c:21: undefined reference to `pow'
  12. misterT
    Apr 19, 2010
    2,697
    368
    Finland
    Well, maybe the -o needs to be after -lm:
    gcc fig04_06 fig04_06.c -g -Wall -I -lm -o
    ... this is driving me nuts :) I don't think it is a library issue though. It should be able to find and access the library ok.
  13. Inquisitive
    Aug 31, 2011
    947
    87
    Georgia, USA
    gcc: error: fig04_06: No such file or directory
    gcc: error: missing filename after ‘-o’
    It doesn't like that.
  14. Styx
    Styx Active Member
    Dec 19, 2003
    1,743
    9
    UK
    nvm..
  15. misterT
    Apr 19, 2010
    2,697
    368
    Finland
    Oh the horror.. I don't know one single programmer that likes makefile.. it is great tool, but not when you have to write it yourself. Usually an IDE creates the file for you. If this is going to be a lot larger project, get an IDE.. or wait until some linux guru finds this post.. or work it out.
  16. Styx
    Styx Active Member
    Dec 19, 2003
    1,743
    9
    UK
    Code (text):
    CC=gcc
    LDFLAGS= -lm
    SOURCES=test.c
    BIN=test
    all: $(BIN)
    $(BIN): $(SOURCES)
        $(CC) $(SOURCES) -o $(BIN) $(LDFLAGS)
    • Like Like x 2
  17. Inquisitive
    Aug 31, 2011
    947
    87
    Georgia, USA
    Problem solved. That works! The makefile now functions as it should and it compiles the program error free.
    I substituted the words "test" and "test.c" with my actual programs name in the makefile.
    Don't understand why it works, but it works.
    Thanks Styx and misterT.
    Help much appreciated.
  18. Inquisitive
    Aug 31, 2011
    947
    87
    Georgia, USA
    Let me ask this then. Right now that makefile must be edited in two places in order for it to work with the next file that is to be compiled. That being the working program name. Can a variable be used inside the makefile that would accept the program name from command line that would then in turn place it into the makefile? So it would not have to be edited each time. Secondly any good tutorials on makefile that you would recommend?
  19. misterT
    Apr 19, 2010
    2,697
    368
    Finland
    Thanks Styx.. :)
Share This Page
