I was hoping someone could confirm that I have this concept correct. If you have a generator made up of permanent magnets on the rotor and coils on the stator when the rotor rotates, it produces a voltage in the coils of the stator. This means that the stator coils produce their own magnetic field of opposite polarity. This is why the generator slows down when you put a load on it because the coils now have more current flowing through them thus producing a stronger opposing field. All of this is called Back EMF correct? Because the rotor slows down under load the voltage also drops off, which is why a governor will then supply more torque to maintain the rpm and voltage thus the required generated wattage...?
Any flaws here?
Any flaws here?
