    Dismiss Notice
Finite State Machine Basics
Discussion in 'Code Repository' started by misterT, May 6, 2013.
  1. misterT
    misterT Well-Known Member Most Helpful Member
    Apr 19, 2010
    2,697
    368
    Finland
    A Finite State Machine (FSM) consist of number of states. For example "waiting for character". When the character comes in, the machine changes to another state. This is called a state transition. There are many ways to implement FSM. Some are complex and some are very straight forward. Using function pointer may sound complex at first, but it is actually quite simple, but powerful way to implement FSM. Below is a very minimalistic state machine that writes "Hello World!" repeatedly using some function write().
    Code (C):
    /* Declare the function pointer. Variable 'state_machine' is a pointer to a function that takes no parameters and doesn't return anything. */
    void (*state_machine)(void);
    /* State functions */
    void hello(void) {
        write("Hello ");
        state_machine = world; // State transition
    void world(void) {
        write("World!");
        state_machine = newline; // State transition
    void newline(void) {
        write("\n");
        state_machine = hello; // State transition
    /* Main function */
    void main(void){
        state_machine = hello; // Initialize function pointer to the first state
        while(1){
            state_machine(); // This is all that is needed to keep FSM running
  2. voidptr
    voidptr Member
    Mar 6, 2012
    50
    2
    Montreal :o)
    your code will not compile for sure ...
    void hello(void) {
    //wrong closing bracket !
    beside that here my 2 cents on FSM ...
    using function pointer is fine and elegant,
    but I prefer to used switch and a local state variable,
    why ...
    - all states of the FSM are enclose into a function or a block of code, more easy to trace while reading the code and more easy to debug too
    - compilers are pretty go at optimizing jump table in a switch, so basicly no a slow thing.
    Code (text):
    static u8 state = 0;
    for(;;){
        switch( state ) {
        case 0:
           state = 1;
           break;
        case 1:
            state = 0;
            break;
  3. misterT
    Apr 19, 2010
    2,697
    368
    Finland
    Thanks for pointing that out.. silly mistake.
    switch-case is the most awful structure in C language. It is so error prone. I prefer "if-else if" over "switch-case". I think it is safer, easier and elegant.. and the compiler does equally good job with it.
    Also I prefer to write human readable code.
    Compare:
    state = 1;
    vs.
    next_state = write_hello;
Share This Page
