Filter design for thermocouples
simon_12
Hi all
I want to design a 2nd order low pass active filter circuit for thermocouples , can anyone has a design of this which you have already tried and works well with thermocouples? What resistor and capacitor values you used?
I have studied the NI tutorials for signal conditioning of thermocouples.It is written that the frequency of thermocouple signal is near about 4 Hz. What is the cutoff frequency that you set ?
Please send me the circuit or a link of this. Any help will be greatly appreciated.
The "frequency" of a thermocouple signal???
Thermocouples are not AC devices, purely DC and millivolts at that.
Are you familiar with the Seebek affect concerning dissimilar metals? The closest thing to AC in a thermocouple signal that you might see would be if a measured temperature is fluctuating with some regular frequency.
Having said that, any variety of noise could be introduced to a thermocouple signal. This is especially true in an industrial environment with significant electromagnetic fields from machinery, motors, transformers, etc.
A lot of your noise filtering approach is dependent on the associated circuits. For instance, a recent poster asked about common-mode rejection in an amplifier circuit for an EKG design. I suggested using a common mode choke to help filter noise that would be present at the amplifier inputs. A thermocouple would typically be using a similar differential amplifier circuit. So a similar noise rejection technique might work here. Also, a simple capacitor to ground from the (+) input of your amplifier, maybe 100 uF, would help eliminate noise at or near mains frequencies.
Can you expand further on the 4 Hz frequency that you have read about? Are you confusing EMI with thermocouple behavior?
The rate of change of a thermocouple (time constant) has to be several seconds, especially when considering the thermal mass of what the thermocouple is attached to. A LPF with a cut-off of 1Hz or so is entirely appropriate.
Download TI's free Filter-Pro cad program and cobble up an active LPF and try it...
Thanks Mike for the software
But if anyone has tried the low pass filter for thermocouples practically. Please send me the circuit or any link in which values of R and C are mentioned.:)
What could be simpler. Put it between the instrumentation amp and the ADC input.
Another example from free software from MicroChip
Hi
Which topology of low pass filters do you think is suitable for filtering of thermocouples? either Sallen-Key topology or Multiple feedback topology.
Would you rather buy two resistors, or three resistors?
Hi
For your application either would be fine. The differences are subtle. For a discussion of these see Design and Dimensioning of Active Filters.
Since the Sallen-Key uses an op amp with a gain of 1, an emitter-follower or source-follower transistor can be substituted for the op amp (with some loss in filter performance) if you want to avoid op amps.
Cool implementation of a three-pole filter using only one opamp...
Keep in mind that an emitter follower introduces ≈0.6 - 0.7 volts of offset, which changes about 2mV per degree C.
Good observation. I forgot that he was filtering a thermocouple signal and DC offset level is critical.
Hi Mike
Please tell me what is the meaning of Seed Resistor Value in the Filter pro V2.0 software and how can i select the desired Op-amps?
Hi Mike
From the help file:
R1Seed Value
The Seed Resistor setting allows you to scale the computer-selected resistor values to match the application. Move the cursor to the Seed Resistor field and enter your seed resistor value. The default value of 10 k ? is suggested for most applications.
When the circuit is in a power sensitive environment (battery power, solar power, etc.) the value can be increased to decrease power consumption. Some high speed op amps require lower feedback resistance, so their seed resistor value should be decreased.
Higher resistor values, e.g., 100 k Ohm, can be used with FET- input op amps. At temperatures below about 70°C, DC errors and excess noise due to op amp input bias current are small. Remember, however, that noise due to the resistors is increased by nwhere n is the resistor increase multiplier. Lower resistor values, e.g., 50 Ohm, are a better match for high frequency filters using a wide range of high-speed amplifiers from Texas Instruments.
The seed resistor value is ignored when a capacitor value is entered.
