I've started watching this show called Dommsday Preppers, you may have heard about it. A bunch of mo-rons on there, and the occasional intelligent person, but sometimes hard to differentiate between them. Anyways, these doomsday types seem obsessed with faraday cages, to protect from an EMP from a nuclear weapon, or from a solar flare. They say a bad solar flare or EMP from a nuclear explosion can take out the power grid, and anything electronic. I'm 90% sure that's correct in theory, but let me describe some of the finer details and mabe you can fill me in, if there's any truth or if it's all just farce. I know nothing about EMPs or faraday cages.
#1 - To keep your electronics safe, just wrap wire mesh around a box made of sticks and put the electronics inside.
I'm almost positive this is wrong. i've seen people make a faraday cage like this, put a walkie talkie inside, and you could still communicate with it.
#2 - "The more you spend on a faraday cage, the less likely it is to work." This guy said that he keeps replacement electronic devices in metal trash cans. The metal trash cans are a faraday cage. He "tested" the principle by putting a walkie talkie in a trash can, closing the lid, and then shorting out his truck battery across the handles with jumper cables. After a few seconds, (probably right before the battery exploded) he removed the cables, took out the radios, and since they worked, it "proves" his theory that the faraday cage did it's job.
I'm pretty sure that passing a few hundred amps of 12VDC through a conductive body in close proximity to a device is not the same as bombarding it with high energy electromagnetism.
#3 - (same guy as #2) - "When an EMP hits, you won't know that anything happened; you won't feel a thing, except that the keys in your pocket will get so hot that that you'll be scrambling to get them out"
This one I'm not too sure, but common sense makes me want to write it off. I know you can heat metal with induction, they have induction forges and I've seen them work. Basically an air core transformer, pumping tons of current into steel rod at high frequency. But I don't think an EMP or solar flare would have the same effect.
#4 - The best protection is to put your devices in a faraday cage, and then put that faraday cage inside another faraday cage.
This one actually sounds plausible to me, but like I said, I have no idea what I'm talking about.
#5 - being underground is better than being in a faraday cage
sound plausible to me.
There are more I can't think of ATM, think I will post them if I remember them.
