expresspcb
I can remove gray back ground on express PCB circuit diagram.
Is it possible to remove grid as well. I enlarged the grid, but still it come on to the printer as a original form.( does not change the grid spacing).
Any idea.
Many thanks.
I believe you can't turn it off when you print it.
It's some sort of safety that prevents using express pcb to make pcb yourself, they want you to let them make your pcb.
No the grid can not be turned off, even changing the color wont work.
The only way that I can get it is to save the print job as a color laser .PS file the convert it to a picture, the change the grid color to white.
Have fun
Kent
Grid problem in ExpressPCB
I also have same grid problem can u plz explain the above mentioned method more clearly i mean the steps and tools etc involved.
