ELECTRONIC SPEEDOMETER INPUT
dleligdon
Trying to replace my motorcycles mechanical speedometer with an electronic one. Many GM 27-168 stepper motors available for a reasonable price. I can not find a data sheet showing the type of input. ma, voltage, or pulse??? Using Adruino for processor.
Motorcycle is a 1973 BMW R 75/5 and NOS units are very expensive.
Thanks for your help, Dave
Sorry, but I missed the connection between the availability of stepper motors for a reasonable price, no less, and an electronic speedometer. :confused:
You don't need a stepper motor.... A simple DC hobby motor will generate a voltage that can be read on the Arduino..
I used one in an Anemometer project and it worked quite well....
Other than that a rotary encoder would serve you better...
Ian:
i think you missed the point. The stepper motor drives the needle. How? Not exactly sure since i never had one apart. it COULD be a one of those funky gears like used in a hobby locomotive and a stepper. So, instead of a linear actuator like you have in a floppy drive, you get an angular actuator. I just don't know. All I know is they call them "stepper motors".
This is a page from VDO explaining how there stepper inst works.
  • VDO STEPPER MOTOR INST.pdf
Ian:
Then why is the title about reading the input???? Driving the electronic output will be the stepper driver, which isn't implied!!
Most gearboxes nowadays have a transducer that outputs frequency.... But "Mechanical" systems are still rotary cable...
This is a stepper motor from a Ford instrument panel & its made by VDO. It used a custom VDO processor to drive it. The instrument panel was driven by the speed sensor on the transmission. It uses a Hall sensor to give a square wave output.
Thanks for all your help. I think VDO data sheet debe showed is what I need. I,ll check out the other links also. Being a retired mechanical engineer gives me a lot of time to tinker and learn how to do new things.
Thanks again, Dave
