    Dismiss Notice
Electret Microphone
Discussion in 'General Electronics Chat' started by jdp12345, Jan 14, 2003.
  1. jdp12345
    jdp12345 New Member
    Jan 3, 2003
    14
    0
    This question revolves around creating a simple microphone that I can connect to my digital recorder.
    I bought an electret microphone and a 3.5MM mini phono plug.
    The max impedance for the Electret is 5uF and Max 10V.
    I know the electret has 2 imputs, voltage & ground.
    When I connect the electret to the plug, do I need to place the appropriate resistor to stay within the 5uF maximum (2.2Kohm)? Or will it be automatically regulated by the digital recorder?
    Also, in many schematic I've seen on the Web, they include a capacitor in the connection of the mic and the audio output. Do I also need to use a capacitor in my connection?
    My digital recorder is an Olympus DS-330.
    In order to make my external microphone work, do I need these 4 parts?
    1) 3.5MM Mini Phono Plub
    2) Electret Microphone 300 - 6Khz
    3) 2.2Kohm resitor (to meet .5uF at max 10V)
    4) Electrolytic?
    or do I simply need the 3.5MM mini plug, the electret Mic and the 2.2kohm resistor?
    I'll try to get pictures of the 3.5MM mini plub, but for now, these are my questions.
    Note: I was under the impression that creating an external microphone was simply connecting the wires together with a resistor(because I'm very new to electronics) and directly to the plug.
  2. herbymcduff
    herbymcduff New Member
    Dec 5, 2002
    205
    0
    USA
    So, are you trying to say that you want to use an external microphone instead of the internal mic on the digital recorder, to record?
    And if so, why can't you just bypass the internal mic, and place your mic in its place?
    And what do you mean it has an impedence of 5uf, and Max 10? Impedence is AC resistance, and is labeled in ohm's, not microfarads. And is Max 10 a maximum of 10V out. And if it is 10V out, surely the internal mic doesn't produce that much out. Plus the voltage out of a mic varies, do to voice.
    Also a mic doesn't have 2 inputs, it has outputs, though you can use the outputs as an input if you choose to use your mic as a speaker.
  3. jdp12345
    jdp12345 New Member
    Jan 3, 2003
    14
    0
    Yes, I want to use it instead of the internal mic
    Yes,
    I want to use it instead of the internal microphone.
    The information on the Electret is as follow:
    .5uF Maximum Current Consumption
    10 Maximum Operating Volts
    JP
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. Pilot
    Pilot New Member
    Jan 5, 2003
    191
    0
    England
    Have a look at the following........
    http://www.eclectic-web.co.uk/index.php?jump=mike/electret_a.htm
    Good Luck.
    :lol:
  6. jdp12345
    jdp12345 New Member
    Jan 3, 2003
    14
    0
    Thank you Pilot
    Thank you.
    -JP
  7. kinjalgp
    kinjalgp Active Member
    Oct 28, 2002
    1,851
    3
    INDIA/USA
    I think it should be 0.5 uA.
  8. jdp12345
    jdp12345 New Member
    Jan 3, 2003
    14
    0
    You're right Kinjal
    Your right Kinjal.
    It is 0.5uA. I apologize how this information threw averyone off track.
    After getting most of the basic information right, with all your help,
    I don't think anyone has done this kind of wiring before.
    All I have received is correction Email postings and not concrete guidance
    for my question. At least, you all have helped me get the correct words in this posting, which I appreciate.
    Thank you to all that responded and to those that didn't.
    Sincerely,
    JP
  9. mechie
    mechie New Member
    Sep 4, 2002
    591
    3
    Lincolnshire, England
    Surely the answer you requested is in Pilot's posting, the website he suggests has a diagram headed "Common or Garden Variety".
    This is a simple circuit to feed the electret's internal pre-amplifier (usually a single FET) with power via the resistor and seperate off the audio via the capacitor - the cap is required to stop the DC power from upsetting your digital recorder's input circuitry.
    Your max 10V rating is the most the electret's internal amplifier can stand before it cooks - much less will be fine - try 1.5v or 3v.
    Use the components in the diagram (there's no magic here - 2.2k or 3.3k will make little real difference; 0.5uF or 1uF it's all the same !)
    Other types of microphone (moving coil for example, or crystal) may require no pre-amplifier - just direct connections to your jack plug.
    NOTE - for those who will be checking, the mic's effective impedance will change with component changes but in the practical world, with a blindfold on could you tell one from the other in a typical hobby application !
  10. herbymcduff
    Dec 5, 2002
    205
    0
    USA
    mechie's right. I checked out Pilots site, and it has everything you need there.
    Also, why don't you measure the output of the internal mic, and try to get your external mic to match it, and just bypass the internal mic.
  11. jdp12345
    jdp12345 New Member
    Jan 3, 2003
    14
    0
    Thank you Mechie
    Thank you for your posting Mechie.
    You're right, I did not include the great help from Pilot!!
    You reminded me that he posted a great web site for guidance.
    Once again, thank you all, especially to Pilot and you (Mechie).
    Sincerely,
    JP
Share This Page
