    Dismiss Notice
EEprom - Reading and Writing
Discussion in 'Arduino' started by Wp100, Dec 24, 2015.
  1. Wp100
    Wp100 Active Member
    Feb 3, 2009
    958
    43
    England
    Something I could do easily in Pic Assembly code but cannot see if it can be done with C++ ..?
    I am declaring a series of control parameters at the beginning of the code, all as single Bytes. eg, temp, timehours, timemins, etc
    I want to be able to store them all in eeprom in one go rather than individually ; as most Arduino examples show.
    During program run these values may be changed, so when the program is restarted, then it will read out the updated eeprom block of Bytes and restore them.
    Is this possible ?
    thanks
  2. Ian Rogers
    Ian Rogers Super Moderator Most Helpful Member
    Mar 28, 2011
    9,159
    907
    Rochdale UK
    ONLINE
    Do you not want to use the "two wire" library??? The Arduino IDE has this library already!!
  3. zahwi
    zahwi Member
    Oct 24, 2015
    186
    16
    This is his wish:
    "I want to be able to store them all in eeprom in one go rather than individually ; as most Arduino examples show."
    We have to put this request to Atmel.
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. Wp100
    Wp100 Active Member
    Feb 3, 2009
    958
    43
    England
    Sorry, should have said Save to Internal EEprom.
    As Zahwi shows, its how can I several Byte variables be saved and restored from eeprom in one operation rather than calling each one by name; probably about 40 Bytes when the program finished.
    Eg
    byte LEDPWM_VALUE = 0;
    byte LEDPWM_PRELOAD = 30;
    byte LEDPWM_INCVALUE = 5;
    byte LEDPWM_INCTIME = 3;
    byte LEDPWM_DAY = 0;
    byte LEDPWM_MOON = 50;
    Zahwi - do not think Atmel will be interested in an Arduino / C++ problem ...?
  6. zahwi
    zahwi Member
    Oct 24, 2015
    186
    16
    Writing to eeprom is limited to about 1 million cycles. It takes several instructions in certain order. It takes about 5ms to write 1 byte. Microcontrollers don't have the option of writing more than 1 byte at a time.
    If you need to update the data often then write it to the RAM and only periodically copy it to the eeprom when the CPU isn't busy.
  7. KeepItSimpleStupid
    KeepItSimpleStupid Well-Known Member Most Helpful Member
    Oct 30, 2010
    9,915
    1,096
  8. Pommie
    Pommie Well-Known Member Most Helpful Member
    Mar 18, 2005
    10,015
    317
    Brisbane Australia
    You do it in C exactly the same way as in asm. What have you tried that didn't work?
  9. Wp100
    Wp100 Active Member
    Feb 3, 2009
    958
    43
    England
    All I can find for writing to EEprom is this Write out a single byte variable " EEPROM.write(addr, val);"
    I have 40+ Byte Variables as showing in entry #4.
    So with that instruction I have to code a EErpom.Write for each variable.
    I was hoping to find some way of indetifying the whole block of byte variables and code it in one function ?
  10. Pommie
    Mar 18, 2005
    10,015
    317
    Brisbane Australia
    Make a table that contains the addresses of the variables and then use a for loop to read/write them. To find the address use the & form. I.E &LEDPWM_VALUE will give the address of LEDPWM_VALUE.
Share This Page
