    Dismiss Notice
Doubly high voltage
Discussion in 'High Voltage' started by TaDa, May 30, 2010.
  1. TaDa
    TaDa Member
    Nov 18, 2009
    124
    0
    Hi! Could I combine the inverter circuits from two disposable flash cameras (each yielding 300V) to yield a 600V circuit?
    I notice that the negative of the circuit on the battery side is the connected to one electrode on the higher pd side of the fly back transformer.
    I believe that so long as they are kept independent on the battery side, 2 of these fly back circuits could be used to generate 600V - Am I wrong?
    Cheers
  2. Sceadwian
    Sceadwian Banned
    Oct 27, 2006
    14,047
    141
    Rochester, US
    You could use a single flash unit to charge them to 600 volts, you charge them in parallel, and discharge them in series. You have to be very careful though as you're starting to get into territory where the voltage can jump 1cm of air.
    I have no idea what would happen if you put two such units in series, don't let them get anywhere near each other though.
  3. amando96
    amando96 Guest
    ONLINE
    Yes you can, but it might not work, ''boots'' disposable cameras are the most well built IMO, other once the voltage gets over 330v, you see smoke.
    also, those capacitors cannot handle all that voltage, and exploding capacitors will make you sh!t yourself :p
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. Sceadwian
    Sceadwian Banned
    Oct 27, 2006
    14,047
    141
    Rochester, US
    If the units would still charge their independent capacitors without interference it wouldn't matter Amando, each isolated circuit would never be exposed to anything over it's normal operating voltage
  6. TaDa
    TaDa Member
    Nov 18, 2009
    124
    0
    As I thought, keeping the charger circuits separate will be fine.
    Cheers
Share This Page
