DC Motor Control Circuit [Deleted]
ElectroMaster
Administrator
ElectroMaster submitted a new article:
DC Motor Control Circuit - Here, S1 and S2 are normally open , push to close, press button switches. The diodes can be red or
Here, S1 and S2 are normally open , push to close, press button switches. The diodes can be red or green and are there only to indicate direction. You may need to alter the TIP31 transistors depending on the motor being used. Remember, running under load draws more current. This circuit was built to operate a small motor used for opening and closing a pair of curtains. As an advantage over automatic closing and opening systems, you have control of how much, or how little light to let into a...
Read more about this article...
am satisfy with DC MOTOR CONTROL UNIT.I NEED ACTIVE FILTER (BANDPASS) THAT WILL DISCRIMINATE TRANSMITTED FREQUENCY FROM A TRANSMITTER AND THE RECIEVER SHOULD COMPRISE OF PHOTO TRANSISTOR THAT WIL DETECT THE FREQUENCY AND WIL RUN THE DC MOTOR CONTROL CIRCUIT
